Jag P-codes
Jag P-codes
I found this list of "P" codes, it may be of use to someone. It was for me, just thought I would pass it along.
- P1000 System readiness test not complete
- P1001 Engine running system self-test not complete
- P1100 Mass air flow (MAF) sensor – intermittent signal
- P1101 Mass air flow (MAF) sensor – signal out of range
- P1104 Mass air flow (MAF) sensor – ground circuit malfunction
- P1107 Manifold absolute pressure (MAP) sensor – signal voltage low
- P1108 Manifold absolute pressure (MAP) sensor – signal voltage high
- P1111 OBD checks complete since last memory clear
- P1112 Intake air temperature (IAT) sensor- intermittent signal
- P1116 Engine coolant temperature (ECT) sensor – signal out of range
- P1117 Engine coolant temperature (ECT) sensor- intermittent signal
- P1121 Throttle position (TP) sensor/mass air flow (MAF) sensor – implausible signal
- P1122 Accelerator pedal position (APP) sensor 1 – signal voltage low
- P1123 Accelerator pedal position (APP) sensor 1 – signal voltage high
- P1124 Throttle position (TP) sensor – signal out of range
- P1127 Heated oxygen sensor (H02S) 2 (downstream), bank 1
- P1128 Heated oxygen sensors (H02S) 1 (upstream), bank 1/2
- P1129 Heated oxygen sensors (H02S) 2 (downstream), bank 1/2
- P1130 Heated oxygen sensors (H02S) 1 (upstream), bank 1
- P1131 Heated oxygen sensors (H02S) 1 (upstream), bank 1 – slow response
- P1136 Engine control module (ECM) cooling fan – malfunction
- P1146 Alternator – charge circuit low
- P1215 Accelerator pedal position (APP) sensor 2 – signal voltage low
- P1216 Accelerator pedal position (APP) sensor 2 – signal voltage high
- P1224 Throttle control position – malfunction
- P1229 Throttle motor – circuit malfunction
- P1233 Fuel pump (FP) – circuit malfunction
- P1233 D Fuel pump (FP) 2 – drive circuit malfunction
- P1234 Fuel pump (FP) control module – control module disabled or off line
- P1236 Fuel pump (FP) not responding to ECM commands
- P1240 Sensor power supply – circuit malfunction
- P1241 Sensor power supply – low input
- P1242 Sensor power supply – high input
- P1243 Sensor ground circuit – malfunction
- P1244 Alternator – charge circuit high
- P1245 Engine cranking signal – voltage low
- P1246 Engine cranking signal – voltage high
- P1250 Throttle valve return spring – malfunction
- P1251 Throttle motor relay – malfunction
- P1254 Throttle limp-home spring – malfunction
- P1260 Vehicle immobilized Invalid ignition key, immobilizer system fault
- P1313 Misfire/catalyst damage – bank 1 Engine mechanical fault
- P1314 Misfire/catalyst damage – bank 2 Engine mechanical fault
- P1316 Misfire
- P1338 Fuel pump (FP) -feedback circuit malfunction
- P1339 Fuel pump (FP) 2 – circuit malfunction
- P1340 Camshaft position (CMP) sensor 2, bank 2 – circuit malfunction
- P1341 Camshaft position (CMP) sensor 2, bank 2 – circuit range/performance
- P1344 Accelerator pedal position (APP) sensor 1/2- range/performance problem
- P1367 Ignition amplifier, bank 1 – malfunction
- P1368 Ignition amplifier, bank 2 – malfunction
- P1384 Camshaft position (CMP) actuator, bank 1 – malfunction
- P1396 Camshaft position (CMP) actuator, bank 2 – malfunction
- P1410 Intake air flap control actuator – circuit malfunction
- P1474 Intercooler coolant pump relay – malfunction
- P1474 0 Intercooler coolant pump – malfunction
- P1516 Park/neutral position (PNP) switch, gear change neutral/drive – malfunction
- P1517 Park/neutral position (PNP) switch, cranking – malfunction
- P1532 Intake manifold air control solenoid 2 (lower flap) – circuit malfunction
- P1549 Intake manifold air control solenoid 1 (upper flap)- circuit malfunction
- P1571 Brake pedal position (BPP) switch – circuit malfunction
- P1573 CAN data bus, throttle position (TP) – message error
- P1582 Engine control module (ECM) – data stored
- P1601 Incorrect ECMITCM fitted to vehicle
- P1603 Transmission control module (TCM) – EEPROM malfunction
- P1606 Engine control (EC) relay – malfunction
- P1609 Engine control module (ECM) – microprocessor fault
- P1611 Engine control module (ECM) – central processor malfunction
- P1611 0 Engine control module (ECM) – sub central processor malfunction
- P1629 Alternator – field circuit malfunction
- P1631 Throttle motor relay, coil circuit OFF – malfunction
- P1632 Alternator/charging system – load circuit malfunction
- P1633 Engine control module (ECM) – central processor malfunction
- P1634 ECM/throttle monitoring – circuit malfunction
- P1637 CAN data bus, ECM/ABS/TCS control module – network malfunction
- P1638 CAN data bus, ECM/instrumentation control module – network malfunction
- P1642 CAN data bus – circuit malfunction
- P1643 CAN data bus, ECM/TCM – network malfunction
- P1646 Heated oxygen sensor (H02S) 1 (upstream), bank 1 – control malfunction
- P1647 Heated oxygen sensor (H02S) 1 (upstream), bank 2 – control malfunction
- P1648 Engine control module (ECM) – self-test malfunction
- P1656 ECM/TP sensor amplifier – circuit malfunction
- P1657 Throttle motor relay, coil circuit ON – malfunction
- P1658 Throttle motor relay – malfunction
- P1672 Engine control module (ECM) – suspension control module – CAN data bus malfunction
- P1696 Controller area network (CAN) data bus- communication malfunction
- P1697 Cruise control switch – circuit malfunction
- P1699 CAN data bus, ECM to A/C control module – network malfunction
- P1710 Transmission control valve solenoids -ground circuit malfunction
- P1745 Transmission low clutch timing solenoid – circuit malfunction
- P1746 Transmission timing reduction solenoid – circuit malfunction
- P1747 Transmission brake timing solenoid 2/4 – circuit malfunction
- P1755 Controller area network (CAN) data bus- communication malfunction
- P1777 CAN data bus, torque reduction – malfunction
- P1780 Transmission gear selection switch D-4 – circuit malfunction
- P1793 TCM, ignition power supply – circuit malfunction
- P1796 CAN data bus, TCM – malfunction
- P1797 CAN data bus, ECMITCM – malfunctio
- P1799 CAN data bus, TCM/ABSITCS control module – network malfunction
The following 2 users liked this post by RodL:
capncraigagain (02-21-2018),
Don B (02-12-2018)
Don B (02-12-2018)
Don B (02-12-2018)
Received 12,932 Likes
The Workshop Manual mentioned by JagV8 contains a fairly complete list of the Diagnostic Trouble Codes (DTCs). You can download the manual in six sections from this forum at the top link Sean posted, specifically:
Table Of Contents
General Information
Chassis
Powertrain
Electrical
Body
The most complete standalone DTC Summaries guide I am aware of is 153 pages and includes most of the Powertrain (P) codes as well as the proprietary Body (B), Chassis (C) and Undefined (U, mostly Network-related) codes. It can be downloaded here:
Jaguar X350 DTC Summaries
I am also attaching an additional DTC manual that contains the best Jaguar Mode $06 data I've found in document form.
As JagV8 mentioned, it really is important to use the Jaguar documentation instead of generic OBDII lists because the Jaguar DTC definitions and possible causes frequently differ from the generic ones. Also, note that the list RodL found omits the approximately 180 Powertrain DTCs with numerals less than 1000 (e.g. P0171, P0306).
Cheers,
Don
Table Of Contents
General Information
Chassis
Powertrain
Electrical
Body
Cheers,
Don
I've got (your one and) one with mode 6 that's rev April 2008, one from May 2005, one from Nov 2003 and another from Nov 2002. They look to be a bit different so here they are - but beware not all jags support all (or even any) of the IDs. And they may not report meaningful data even if they reply to an ID!
(Some/all of these may be in the large file area / Gus's site.)
Oh - I also have one for V6 with the Denso PanPAG but who has a V6?
