Jag Wouldn't Start
Old 02-21-2024 | 11:50 AM
jagxjr's Avatar
Q. What if relay mounted in starter busted?
Are you going to buy $100 starter because of $5 relay
Old 02-21-2024 | 12:22 PM
NBCat's Avatar
You don't mention if there are any DTCs stored.
Old 02-21-2024 | 12:31 PM
NBCat's Avatar
See Electrical Guide, Fig. 02.2 for starter motor circuit details. Starter relay is in Front Power Distribution Box.
ECM controls circuit through pin PI1-041 STARTER RELAY DRIVE: TO ACTIVATE, ECM SWITCHES CIRCUIT TO GROUND
If you have all the manuals, have you performed any pin tests to determine if you have complete circuits?
Old 02-21-2024 | 01:52 PM
jagxjr's Avatar
Originally Posted by NBCat
... Starter relay is in Front Power Distribution Box
Thanks for taking your time.
You see, that is my problem. There are no relays markings in image of fuse box
pointing to that relay and schematic diagram point to something only some
car electrician would understand and I'm not one of them. If you have picture
of fuse box with arrow pointing to relay, please post it to help me and hundreds
of people who will be eventually visiting this forum.
Old 02-21-2024 | 02:12 PM
jagxjr's Avatar
I just found something in my pics related to my issue but... I have bad news.
According to pic above, starter relay is R10 and if you look at pic below, that
relay is bundled with some others in a brown relay box.
Attached Thumbnails Jag Wouldn't Start-fusebox1.psd
Old 02-21-2024 | 05:57 PM
NBCat's Avatar
I don't currently have access to an X350 to help with identifying the relay.
If you have found the distribution box, you can swap relays around if they're the same shape and have the same number of male connectors.
Old 02-21-2024 | 07:32 PM
jagxjr's Avatar
Well, that's the problem, you can't replace that relay separately because
of where it located. As I said, it's bandaged with other relays.
  #28
Old 02-21-2024 | 08:42 PM
h2o2steam's Avatar
Those relays with an asterisk * beside them are referred to as system replays.
That simply means they are incorporated in the power distribution fuse box circuit board construction - soldered in and not readily user replaceable unlike their socket counterparts that you can simply pull out and replace as needed.
System relays can be replaced if the fuse box is removed and then fully dismantled, but you need some soldering skills and set aside a couple of hours to do that job.
A Dremel with a fine cutting metal blade to cut the 100+ links that join the front and rear PCBs together is very helpful to separate the PCBs to get to the faulty relay's soldered connections, then it is just a case of bridging across the links you cut to put the two PCBs of the power distribution box back together again.
NBCat (02-22-2024)
Old 02-26-2024 | 08:28 AM
OldKarz's Avatar
You can check the output of that relay if you check for voltage at starter relay activation input on starter motor. Will show whether the system wiring to that point works or if it is the starter relay activation relay in the box. Then check the input to the relay from the ECM. It should turn on if the ignition is turned on and there security checks were verified. Either test can be done first.
slmskrs
07-15-2019 11:48 AM
b787
06-18-2015 06:08 PM
Bigvettefreak
08-01-2012 01:48 PM
bigcat01
06-20-2011 10:21 PM
chokeu2
02-17-2011 10:37 AM
Quick Reply: Jag Wouldn't Start
