Jaguar cant fix
Transmission problem shifiting into 6th gear when getting onto highway. Jaguar
did all test and found no fault codes for transmission. If I drive slow it will shift ok but any excellerate over 2500 rpms it will not shift in 6th gear. If iam on the highway it will finally shift to 6th gear at about 85 mph. It is not in s mode. It will also shift into 6th gear if I pull it to 5th manually and go back to drive. 10 hours at Jaguar and they dont know how to fix the problem. Anyone know of this problem? 2004 xj8. Tx
![](http://images.intellitxt.com/ast/adTypes/2_bing.gif)
Hi tiaaa, I have moved your post to here, because you say you have a 2004 XJ8. Hopefully more people will see it. (but please avoid making multiple posts about the same issue in other forums, it will just dilute any replies and can lead to confusion).
Hope you can get your problem fixed soon, and please post up the solution when you find it.
All the best,
All the best,
after 10 hrs at jag dealer and five days at tranny shop know one could fix problem. was not shifting out of 4th and 5 th gear with moderate driving. If driven slow it would go into 6th gear. Jagtec1 told me to check tire debth which i did. Front had about 80% and rear had about 90%. the wear looked good. I switched tires front to rear and bingo. Shifts every time to 6th reguardless how i drive. Its hard to believe that solved the problem. This had been going on for months. Thanks to Jagtec1 he solved the problem!!!!!!!!!! Thanks Jagtec1. Bob
![Icon Razz](https://www.jaguarforums.com/forum/images/smilies/icon_razz.gif)
Drew,
If you go with staggered rim diameters, you want to make sure the overall tire diameters are close to the same as fronts. There will be ABS issues too if the wheels are not spinning within a 15% rpm variance as an overall limit, and Jaguars might be even tighter. The ABS interprets such variation as wheel spin.
There are some good aspect ratio calculators online. They can get you very close to zero % variation with staggered rim diameters.
X_Type_South_Africa
12-09-2015 05:37 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
