Jaguar Engine Interferes with iPhone4 Ack!!!
OK. This is just a weird problem. Here's the background...
I have a 2005 Jaguar XJ8L with about 52,000 miles on it. Great car. Love it. I have a new iPhone 4. Great device. Love it. The combo of the two... Not so good.
When talking on the phone in the car NOT in speaker mode and NOT using a headset, I hear an annoying clicking from the phone and it sounds to people on the other end like I'm "talking into a fan." Another person described it as "being attacked by a swarm of angry moths."
In any other car the voice quality is fine. In MY car with the engine OFF the voice quality is fine.
In my car with the vehicle ON and all the electronics running, but the engine OFF, it's fine.
The minute I start the engine, the call quality goes down the tube.
If I switch to speaker or headset the quality is fine again.
The problem only happens in that car on that phone using the normal handset mode.
Setting aside the fact that using a headset or speaker is probably a safer way to drive, I'm concerned that there's potentially enough EMI coming from my engine to disrupt an electronic device like a cell phone in the car. It makes me wonder if there is some piece of electronics about to go bad.
This problem didn't happen with my iPhone 3G or any other cell phone that I can think of. I've already resigned myself to just using the headset, but I still want to figure out the root cause of the interference.
Apple already replaced the phone for me and it made no difference.
My next step is to go to the Jaguar dealer and ask them to replace the car. No, not really. However, I AM going to go start one on the lot that is the same model and similar year to see if it's just an iPhone vs. XJ8 thing, or if it's just MY car.
Weird huh? Any thoughts?
maybe it is an improvement but they are so in advance that you can't understand...lol...sorry about it....I am so ennuyed with mine...the deal about waiting to get feature on a new vehicule sounds pretty pitty ...too...not to agravate the situation....
The sonar waves are picked up by the noise cancellation mic in the iPhone 4. That is why is works ok in speaker and with a headset (the NC mic is turned off). All you can do is tape over the sensors. That should work. Or, use a headset. Problems are reports on all late model Jaguars that use this system.
This seems to be the culprit. Apple had no idea of this problem. Jaguar seems to be aware.
Sol
I think it is sad,knowing how the value of a new vehicule depreciate so fast ,if they can sell one at his full value without delivering all options,for the first so important months.
see how I struggle with a car under warranty and how lazy and lenghty they are at repairing it right and giving appoitments 3 weeks appart since April.
all the time it is not on their side,it happenned to be on the good tolerance of buyers and sometimes I think jag goes too far.sorry to day so.I do not see the point of doing previous test drive to deliver the car not complete.
well you guys with new xj has not experienced what I did,and you probably have a great handling etc...all the best...personally and with my own and past experience I will refuse to pay the full value of I can't get the full options working,and I will not care at how nice ,and subtle the seller is,or and how good he can be,I do not care of this.
yeah so I just called Apple to get a new Iphone 4 sent to me. Then I sat down and read this. This sucks. I cant even use my phone in the car. Im pissed b/c I left Tmobile using the original iphone and had a $65 a month bill. Now im on ATT with a more expensive bill and will be using the same phone but for $20 more a month!
Guest
Posts: n/a
I just took delivery of my new 2011 XJL and was trying to connect my iphone 4 to the car via bluetooth. I still have not been able to get it working 100%. First off, when I use the car's search for bluetooth device it doesnt find my iphone 4 at all. instead, I use the "use handset" option to pair the devices and that works OK. it definitely connects, but nothing from the phone gets downloaded to the car (contacts, recent calls etc...) and the car doesn't list the device in the device list which means I know there is a "dirty" connection. More importantly, when I shut the car off and leave it off for a while, it forgets the pairing between the two devices so I have to start the process again. This sucks !!! Anyone else connect their iPhone 4 to their car via bluetooth and get it working? Thanks!
The problem is the sonar waves emitted from the sensors in the ceiling and dash of the vehicle. These sensors determine whether someone is in the front seat and activate/deactivate the airbags accordingly.
Sol
Sol
my bad i was thinking or land rover
but on a side note, sonar sensor is actually how the new jaguar 5.0 liter checks oil. theres no dipstick
pkp124
I got my iphone 4 to work properly with my 2011 XJL without any problems. Here's what I had to do. I first make sure my iPhone 4 bluetooth is off and hop in the car. Start the car and push phone button and the car computer searches for bluetooth phone. At this point turn on bluetooth function of the Iphone 4. The car computer will find the iphone and pair up/dock with it. All the normal functionality will be there. Subsequently the process of pairing with your iphone will be automatic. I don't get any interference or signal problems either. I believe the trick to get the initial pairing is timing. The car computer has to be searching before the iphone 4's bluetooth system starts searching to get the right sequence. try it...hope it works for you.
Guest
Posts: n/a
Thank goodness for this forum. I just got my iphone 4 this weekend. Works GREAT except when I am in my 06 xkr.
Everyone was telling me they had tons of background noise when I was talking to them. I came home made a call everything was fine.
Drive my ford ... everything was fine.
Got back in my Jag this morning.... background noise. I couldn't figure it out until I came home and I was talking to someone and I pulled in my driveway and turned my car off. The noises stopped. turned the car on.... didn't start the car.... NOISES! Doors closed, No radio, no A/C, no nothing. Just key on the on position.
I guess I am returning the phone today. LOL. Thank goodness it wasn't just me. LOL
