Jaguar Key Fob 2001 to 2009 Facts All You Need to Know FAQ
Received 6,327 Likes
Jaroslav Záruba (11-07-2023)
Transponders are generally 'passive' devices - they don't need electricity. They typically work at a range of about 1-15 cm (0.4 to ~6in). The transmitter for the buttons on the remote are what need battery power.
- Simplified: Once the key is inserted into the ignition lock and turned the ‘on’ or ‘run’ positions, the induction coil mounted around the ignition lock sends out an electromagnet field of energy. The windings in the transponder chip absorb that energy, power the electronic chip to emit a signal (usually an alphanumeric code). The induction coil reads the signal and sends it to ECU to recognize the signal. If the signal is recognized, the signal is accepted and car starts
The following 2 users liked this post by hafren:
camillo (08-02-2019),
#28
#30
#31
Wolfy, the lock and unlock buttons are used the most on the key fob. When you push the button there should be a crisp click being achieved from the micro switch. If not a crisp click the micro switch may be becoming worn out. Compare the feel to say the headlight or truck button. Do they always work on first click and have a nice click feel? Micro switches are sold on eBay that would require a steady hand and good soldering skills. Otherwise buy a used key fob button portion and reprogram to your car.
#32
#33
there are people who take your fob and replace the microswitches. They advertise on ebay and possibly in some of the car enthusiast magazines. You can also get a new rubber insert if the print is wearing off. Or you could just get a new/used fob and program it to your car. It can be removed from the key and transponder part quite easily. It's useful to have a spare.
jagit (06-28-2017)
#36
Just needing a tibby key replacement....getting the job done at the lowest cost if you purchased a used key fob on Ebay and just need a new tibby key shaft to fit your car. Here is the latest info. as of today.
Here is a seller on ebay selling the tibby key blank (metal/chrome style) for only $8.95 with free shipping out of California.
New Uncut Replacement Flip Key Fob Uncut Key Blade Blank Key | eBay
The jaguar dealer, for instance, in Lake Bluff, Illinoise only charges $5.00 to cut the blank you provide and a lock smith in Racine, Wisconsin will also cut the blank you have for only $5.00. (of course the Jaguar Dealer will also look at you and say, you will need to have the keyfob programmed to your car in order for it to work!
for me I already programmed it myself so just rementioned to him that I just need a cut....always fun to see them look at you like...how did you do that
, and with that they cut it within minutes).
If you prefer, you can buy the tibby key blank and have the same seller cut your key all for $15.00 USD plus $6.00 shipping as it is from the UK. He does excellent work and uses the origional brass key blank versus some others that use the metal/chrome blank. Both blanks work great, it is just a matter of preferance.
Jaguar Replacement Flip Key Blade for 4 Button Free Cutting | eBay
Here is another seller on Ebay out of the UK that other forum members say does a great job on providing the tibby key blank and cuting it for you at about the same cost as the other UK seller above. This seller uses the metal/chrome type key blank.
Jaguar Flip Blade Car Key Replacement Cut for Remote Fob XJ XJR x s Type | eBay
I myself have 5 key fobs all working great and programmed to my car all at a rather low cost comparing to what many other forum members have paid.
Happy Key Fobbing!
Happy Key Fobbing!
The following 2 users liked this post by lcmjaguar:
hafren (02-01-2015),
Jumpin' Jag Flash (03-14-2017)
#37
Hello All,
I have decided to write up a very comprehensive article about unlocking all the secrets to the 2001 to 2009 Jaguar Key Fob, how it is made, how to get a key blank and key blank made, how to program the transponder to the car's ignition as well as how to program the key fob remote button portion to your car, all without the need for a Jaguar Dealer in most cases!
This is a very informative article so enjoy and benefit!!!![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
Happy New Year!
LCMJAGUAR
2008 XJ8 VDP
1988 XJ6
Happy New Year!
LCMJAGUAR
2008 XJ8 VDP
1988 XJ6
Here are the steps my friends:
1. Insert original fob key for two seconds noting the security light solid to the second position before running the starter then Pull the key out quickly
2. Repeat the same with the valet key or second original fob key
3. Repeat the same as #1 with every New key fob or key
Congratulations! You just duplicated your transponder New key fob and/or new key
The Jag Specialist
The following 2 users liked this post by jagspecialist:
Jumpin' Jag Flash (03-14-2017),
marbuch (10-18-2015)
#38
Having read through all the threads on this subject. I have deduced that in my case I probably need to seek some professional help.
I have tried numerous attempts to re-programme my fobs with no success.
I get the chirp after the fourth headlamp flash but no reaction to pressing the fob buttons and after 30 seconds the system times out with a chirp followed by two pips signifying failure and unless anyone knows better ? I believe the system requires resetting to register my two fobs.
So with a growing sense of trepidation I will open my wallet and approach the "Robber Barons"
Greytop
Greytop
#40
Donzi (10-18-2015)
