Jaguar Key Fob 2001 to 2009 Facts All You Need to Know FAQ
#102
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Success story! I ordered two aftermarket keys off Ebay, and took them to the dealership for cutting this afternoon. After a stern warning from the Service Manager not to think about circumventing his consultation fees, I was met by an affable Parts Department attendant for cutting. I was out the door in ~15 minutes all told.
Thanks so much lcmjaguar! Attached in my post is a duplicate of lcmjaguar's original key memo in PDF format
In summation, I spent $28 on the keys and $21 on the cutting service. Right under $50 for two extra keys + fobs, programmed. Because I already had two functioning keys and no faults in the Security Module, I was able to self-associate the transponders without resorting to SDD. It took several trys to get it right, but I found it easiest to perform the steps quickly, such as:
https://www.ebay.com/itm/2-For-03-20...b/123965851881
When programming key fob: The series of four flashes need to be quick (half-second holds, maximum); and 5 "program" actions need to be performed
When programming key (ignition transponder): Quickly set both associated keys in, then out, of Position 2, and minimize time between transferring keys
The key I bought is linked below; no guarantee it will work for other people's cars but good luck to those of you looking to try it!When programming key (ignition transponder): Quickly set both associated keys in, then out, of Position 2, and minimize time between transferring keys
Hello All,
I have decided to write up a very comprehensive article about unlocking all the secrets to the 2001 to 2009 Jaguar Key Fob, how it is made, how to get a key blank and key blank made, how to program the transponder to the car's ignition as well as how to program the key fob remote button portion to your car, all without the need for a Jaguar Dealer in most cases!
This is a very informative article so enjoy and benefit!!!![Icon Banana](https://www.jaguarforums.com/forum/images/smilies/icon_banana.gif)
Happy New Year!
LCMJAGUAR
2008 XJ8 VDP
1988 XJ6
Happy New Year!
LCMJAGUAR
2008 XJ8 VDP
1988 XJ6
#103
#104
The short answer is no. The car allows you to add additional keys if you have two programmed keys. You would need access to Jaguar SDD dealership software, or consider reaching out to forum member Sone, who offers a key cutting + transponder programming service. (Link below is his post in Marketplace)
https://www.jaguarforums.com/forum/market/227433
Of course, you can have this work done at dealership, but with the understanding it will be $300+. In my town, locksmiths advertised cutting the 6-cut TIBBE keys used in our cars, but I didn't try them. Lastly - once you have two keys programmed to the car - you'll be able to add your own! See my post above, I was able to get two extra keys cut, then self-programmed to my car, at $49 total.
EsRay (09-26-2020)
#106
#108
Thanks for thread
I have a different problem with both keys.
I put them in and not always does the immobilizer recognize them. Sometimes the car starts first time and some times it starts after 4 or 5 attempts/turns.
I get steering wheel locked and lights flash twice when car does not ignite.
There is no pattern. I just don't know what will happen any time I go to start the car. It is the same for both keys.
I have replaced batteries and cleaned thoroughly both keys inside and out.
Do I need new keys or is there a problem with immobilzer?
Any help would be greatly appreciated
#109
Whenever you want security professionals, always contact a local locksmith because they arrive at your location to solve your problem permanently. Moreover, they charge genuine fees from their clients as compared to other security professionals.
Will they come to Israel?🤣
#110
"..... It is the same for both keys."
I'm not sure about the problem might be , but I would think this is a good indication that its probably not the key transponder problem.
Paddyh wrote:
"Transponders are generally 'passive' devices - they don't need electricity. They typically work at a range of about 1-15 cm (0.4 to ~6in). The transmitter for the buttons on the remote are what need battery power.
- Simplified: Once the key is inserted into the ignition lock and turned the ‘on’ or ‘run’ positions, the induction coil mounted around the ignition lock sends out an electromagnet field of energy. The windings in the transponder chip absorb that energy, power the electronic chip to emit a signal (usually an alphanumeric code). The induction coil reads the signal and sends it to ECU to recognize the signal. If the signal is recognized, the signal is accepted and car starts."
#111
I think it might be steering wheel lock electrical fault
Probably need a visit to the dreaded dealership
#112
Hello All,
Happy New Year!
LCMJAGUAR
2008 XJ8 VDP
1988 XJ6
Happy New Year!
LCMJAGUAR
2008 XJ8 VDP
1988 XJ6
Thanks.
#113
Could you tell frequency of the key fob circuit board based on its physical appearance? Looking at my key fobs serial number 1X43-15K601-AJ your list suggests it is a 315MHz one. However, when I look at the circuit board and compare it to a number of circuit boards at ebay.uk it looks like 433MHz one. I live in Indonesia, by the way, and confused which one to buy. A store in Australia offers circuit boards with both frequencies.
Thanks.
Thanks.
The frequency for the key fob depends on what market the car was originally made for. If your car was sold new in Indonesia, it is 315MHz.
Here is the page that gives the fob frequencies by country.
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1319x685/locking_freqs_by_country_ed6ccdb92481ed08bd6b57cde1a754db0cb76641.jpg)
Lock fob frequency by country
For example, I live in New Zealand which is region 3, but my car was made for Japan, which is region 1. My fob works on 315MHz.
Pete M
Tigre (10-12-2022)
#115
Hello All,
Happy New Year!
LCMJAGUAR
2008 XJ8 VDP
1988 XJ6
Happy New Year!
LCMJAGUAR
2008 XJ8 VDP
1988 XJ6
After inserting the first and second working keys, I inserted the new key but the red light on the dashboard kept blinking for about 20 seconds before it went out, and the new key didn't work. The transponder was there inside the upper part. I suspect the key came with a wrong transponder specification; an ID60 chip. Upon browsing online shops I found out there are a variety of transponders: ID46, ID48, ID60, ID63, ID67, ID4C, ID13, T6, 4D63, ID46 PCF7936, G, 4D65. Which one should I get to make it work?
#116
Would like to update you all on my attempt to make a third key, which I posted on November 6... I browsed around to find suggestion on types of transponder, found out somewhere mentioning ID13 or T13, forget exactly, unsuccessfully. Then speculated with the so called "SuperChip XT27" still didn't work. Finally out of curiosity I decided to get an Xhorse VVDI Mini Keytool, costed me $129. Things we solved in 5 minutes, cloning the working key using the toll and the superchip; the toll specifically asked for a superchip; it would do anything with the ID60 that came with the key fob.
Like the small key tool so much this $129 investment would help me do other things, including cloning key fob for other car as well.
#117
Truely one of the most timeless threads !
Thanks to lcmjaguar and all contributors from someone who just now became proud owner of a full set of 2 working FOB keys and 2 working valet keys within only a few minutes of sitting in the driveway.
After years with only one working key I finally came across this, tested and found that one of the valet keys also started the car and so taught the car to listen to the other 2 keys, too. Happy, and much safer against accidentally dropping a key some time and be stranded and at the mercy of OEM prices to fix my dilemma
Jaroslav Záruba (11-06-2023)
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
