Jaguar Logo Light in Truck
Jaguar Logo Light in Trunk
With all of Evan Trinh's outstanding modifications to his XJ, I liked the trunk Jaguar Logo light idea. I took a different approach as to not to modify the car trunk liner by mounting a projector light in the middle of the trunk liner which would entail cutting a hole in the liner but rather I modified the existing light that is at the top of the trunk lid next to the pull tab emergency release cord. I took a Jaguar logo projector light, removed the electronics and transferred over to my other original light and drilled a round hole for the projector to shine through. Had to do this as the projector light is naturally at the wrong angle for trunk use but works great as a plug and play device for the doors for which they were originally designed. Looks completely original to the car still. Just plugged it into the socket. I have attached pictures, turned out rather nice; but you be the judge.
The following 3 users liked this post by lcmjaguar:
Here is the puddle logo projector light in the door. Simply pop out the existing light, remove the wire harness by pulling it off, then simply plug this type of logo projector light by attaching the wires into the harness and pop back into place into the door. That is all there is to it. this style of puddle logo projector light can be found on Ebay.
