Jaguar VDP won't start or turn over
@Oldmots, when the TB fails the messages are "Engine system failure, DSC not available, Park brake failure". He is missing the "Engine system failure", but has "Air suspension fault", "CATS Failure" and "Transmission failure".
I would suspect the ECM can not talk to the TCM and determine if the car is still in gear or not. But that is sheer speculation and no idea what the root cause might be.
Hmmm - I just saw your error messages. I'm not a mechanic or even mechanically inclined besides changing a headlight. Unfortunately, I just regurgitate things I've read or researched on here. I haven't seen anything on here that talked about your issue.
Sorry I couldn't be of more help.
Given the number of error messages I would say your kitty is in serious coma. The obvious choice is to transport it to a professional.
If you have some skills and time to invest get a Mongoose JLR tool and a copy of the Jaguar SDD software and see what the car computers are willing to tell you. The first thing that software does it try and talk to all computers in the car, that would tell you which ones are talking back and if some module is dead. That would give you a good starting point.
The relays were the ones under the hood. By looking at the handbook none of the relays seem seem relevant to the car's dormant stage. Some of the small fuses under the hood serve more relevant functions and I didn't pull any while the car was running. I'm going to check those fuses again that control the ecm, tcm and ignition. I hope you may come up with something and I'll keep you posted on any progress. Thank you.
Oldmots, I returned under the hood tonight after having checked every fuse and every ground including the MEGA fuses in the trunk. I started to press all the relays to make sure they were seated properly and as I pressed the starter relay it made a sound as if a connection had been stablished. I went inside the cat and it started right up. I think that many no start problems may be the starter relay no making proper contact even when it looks properly seated. THANK YOU!!!
#28
No problem - people on this forum have always been willing and able to help me when I have questions or issues. So, I try to help out when I can. Before I bought my Xj8, I went through every thread in the x350 section.
Esloser, I went back under the hood and checked all the relays by making sure they were properly seated. As I pressed and moved the started relay I heard a sound as if a connection had been made. I went inside the cat and it started right up. I think that many no starts may be traced back to the starter relay. It looked properly seated. Thank you for your support and concern!!!
BrentGardner
28
04-26-2024 03:08 AM
philwarner
12-06-2021 07:13 AM
1964Daimler
09-02-2015 11:41 PM
SingBlueSilver
08-27-2015 02:20 PM
