Jaguar X350 Brake Issues
Old 01-09-2015 | 11:36 AM
88MPH's Avatar
Default Jaguar X350 Brake Issues
Hello everyone,
Please can someone help. I have a brake issue with my X350.
I changed the brakes all round about 400 miles ago.
Just recently when I started the car the pedal travel before any biting point for the brakes had more than doubled. It's just like there is nothing there at all until I get to the biting point.
I have also noticed that with the engine off the brake pedal does not go rock hard and allows the pedal to travel to the floor. Please correct me if i'm wrong as I've always thought the pedal should have no travel when the engine is off?
Finally with this issue I have no warning lights whatsoever.
Any help or advice is greatly appreciated.
Thanks in advance
Adrian
Old 01-09-2015 | 11:38 AM
chadkarol's Avatar
What type of brake work did you do? Did you replace calipers, rotors, and/or pads?
Old 01-09-2015 | 01:12 PM
Lagonia's Avatar
Sounds like air in the brake system. Has the brake fluid been bled off?
Now if you have had the ABS controller disconnected and managed to get air in them, that would be hard to expel. You would almost assuredly have to use the right scan tool (IDS/SDD or other capable scan tools) to help you bleed the ABS controller.
AD2014 (01-10-2015)
Old 01-09-2015 | 05:32 PM
user 2029223's Avatar
Banned
Sounds like air in the system. Look for a leak. Start with the fluid bleed thingies.
It's normal to have a firmer pedal after engine start.
BrentGardner
28
04-26-2024 04:08 AM
Doberman_Fan
22
12-24-2019 07:21 AM
nelsonht
08-30-2015 07:01 AM
Andrew McVey
16
08-27-2015 08:21 PM
NinoGrimace
08-26-2015 06:15 AM
Quick Reply: Jaguar X350 Brake Issues
