Jaguar xjr 2005 feul pump
Thank you gents. This post caught my eye. I have read some member's experiences on the forum but decided to dig further in case I need to replace the twin pumps inside the tank of my '04 XJR.
So if I am correct, this is some of what I discovered:
Not all XJR cars have two pumps
The requirement for XJR pumps are more that of XJ8 cars with normally aspirated engines.
XJR pumps require up to 180L @ 4.0 bar and are speed controlled.
If you are handy, you can replace the motors inside the assembly without changing the entire assembly.
Some resourceful forum members have used BMW M5 pump motors in XJR cars.
Some original twin pump motors were Pierburg 7.22013.61.0 . This pump also crosses to the Pierburg 16146752369.
See https://www.ebay.com/itm/23269167278...UaAhS_EALw_wcB
and https://www.ecstuning.com/b-pierburg...MaAoafEALw_wcB
1. Correct me if I am wrong about any of the above.
2. Please recommend other pumps that you trust to be from good manufacturers. Walbro pumps look good but they do not seem to offer XJR or M5 replacements . I do not care to use a no-name brand for $20. I mean , I would like to pay that but I fear noise and failure .
3. Did Jaguar use identical pumps in the "twin pump" XJR.?
this person put the regular pumps in their car like 5 years ago.
@Lagonia
still using those $40 pumps? everything good?
abonano
07-30-2018 06:55 AM
Avro RJ
11-16-2015 08:19 AM
