Joined the Caldoofy Club!
Old 05-06-2015 | 10:58 PM
Naso--Lituratus's Avatar
Default Joined the Caldoofy Club!
Yay.
All the way from the sunny isles of the U.K.
My intake has arrived.
Like it. Quite the difference.
The following 7 users liked this post by Naso--Lituratus:
anindyam (05-13-2015), caldoofy (05-07-2015), Cambo (05-06-2015), Don B (05-06-2015), lcmjaguar (05-07-2015), nycturbovr6 (06-15-2015), Sean W (05-07-2015) and 2 others liked this post. (Show less...)
Old 05-06-2015 | 11:05 PM
Cambo's Avatar
Really a great "bang-for-your-buck" modification aren't they
Random question, you still have the air-lines running to your shock towers?
The following 2 users liked this post by Cambo:
caldoofy (05-08-2015), nycturbovr6 (06-15-2015)
Old 05-06-2015 | 11:11 PM
Torrid's Avatar
It looks like he has them tucked into the openings. I coiled mine up and zip tied them behind the headlamps under the radiator cowl.
Old 05-06-2015 | 11:15 PM
When I first saw it, I was like " damn, pretty expensive little tube..." But after the drive I was happy. Big sound difference.
I have yet to remove them, and I forgot to ask the guys who did the swap to remove them, they are just zip tied so they wont wiggle about.
Think I should go Dyno again, get a direct before and after for the exhaust and intake mod vs stock?
Gotta be worth a few ponies right?
Old 05-06-2015 | 11:21 PM
Cambo's Avatar
When these intake tubes first became a thing, a few guys did dyno runs and picked up an average of 10rwhp. So they do actually make a difference.
Even if they brought no power, the increased blower whine makes it worth every penny.
Naso--Lituratus (05-06-2015)
Old 05-06-2015 | 11:33 PM
I agree, it really is a big difference.
Old 05-06-2015 | 11:43 PM
Karaudio23's Avatar
First mod on my must have list.. Is it just a 3" tube with 2 3" silicon clamps?
Old 05-06-2015 | 11:44 PM
Karaudio23's Avatar
You could just run a catch can for the pcv id imagine
Old 05-06-2015 | 11:45 PM
Karaudio23's Avatar
For $230 I'd at least expect some pretty t bolt clamps!
Just? Just you say??!
Yea pretty much. Air line outlet too. I wanted to keep the stock box so I went this over mins. Expensive but sexy.
Old 05-06-2015 | 11:50 PM
Before I purchased, I was at the place that did my dyno, well known group of smart good techs.
They said that if they were to.make this for me, it would be more than 230.00$, if that means anything to you.
Old 05-06-2015 | 11:52 PM
Karaudio23's Avatar
Lol.. I'm going to toy with making my own if I don't like the results I'll be ordering one too!
Old 05-06-2015 | 11:54 PM
Karaudio23's Avatar
Is the end that butts up to the upper intake round or actually shaped like the oval on the upper intake?
Old 05-06-2015 | 11:56 PM
It is round. The trickiest part to make would be the small side outlet. Other than that it is pretty straight forward. I think it is worth the money.
Old 05-07-2015 | 12:14 AM
Karaudio23's Avatar
Ps love the racing green!
Old 05-07-2015 | 12:42 AM
34by151's Avatar
You might want to consider ceramic coating the tube as I did with mine
https://www.jaguarforums.com/forum/x...e3/#post720811
This helps a lot with heat soak as the new tube stores the under bonnet heat unlike the OEM plastic tube
You could also have it powdercoated but that will not give the level of heat protection but will make still make it look more stock
34by151
Old 05-07-2015 | 06:12 AM
caldoofy's Avatar
Glad you like it :-)
Old 05-07-2015 | 06:22 AM
caldoofy's Avatar
Not quite, if you want to replicate you will need to source 80mm stainless tubing for the main section ( the air box tube is 80mm and 3 inch or 75mm tubing would be a restriction), incidentally I have this tubing size custom made, then using stainless bar stock machine the specific oil breather connection before welding it on, the joiners are also 80mm quad re-inforced silicone, the clamps are stainless jubilee clips, do the job and are used to keep the costs as low as possible for the purchaser obviously these could be changed if required but I see little point.
Hope that helps.
The following 3 users liked this post by caldoofy:
anindyam (05-13-2015), Don B (05-07-2015), psg (05-07-2015)
Old 05-08-2015 | 12:20 AM
XxSlowpokexX's Avatar
Believe me...I was going to make my own tube and quite honestly it just wasn't worth it, This intake is a piece of art and fits awesome...I have mine connected to a Mina intake kit,,,Talk about loud...And do a before and after boost check...And youll see why you get those extra ponies. Havent been able to get to dyno yet to see what my gains but I can DEFINITELY feel the difference. Upgrading the MAF and TB soon..Just waiting for that dyno run first. And at full throttle the metal tube wont transfer heat to the airstream. So I wouldn't worry about that.
Old 05-08-2015 | 05:06 PM
Karaudio23's Avatar
Thanks for the info! Snow.. Have you found a larger maf to replace the stock one? If so what is required to install it?
Quick Reply: Joined the Caldoofy Club!
