Just opinions on these Rims...
Ok fellow members, you don't have to give me the spill about "whatever you like best & so on". I get that, but I just want "your honest opinion".
Both Rims are the correct measurements for our cars, so no issue there. 1 set is $1100 & the other is $1500, so not a huge deal there either. Again, I pretty much have my mind set, so as I said, I just want opinions if that's ok
The 1 rim pic is a the NICHE SURGE BLACK MACHINED.
The other set, I believe most of us know what those are!..
OEM preferred here though I don't mind running newer vintage rims on an older car.
For example, 2014 Aleutians on any year x350...
Or Rims from another model; example XKR rims on x350 (hopefully bigger and/or wider).
That said, Sentas...
Thanks-
Mag
Thanks-
Mag
For some reason I had a feeling it was the LS. Just seems like that's the Lincoln that 1 with a jag would have...
Marque,
I also support putting OEM rims.
IMHO the Aleutians are nice on an X351 but look odd on an X350.
Of the two models you show though, I agree with you and my vote goes for the Niche wheels, they look closer to an OEM Jaguar look.
Also, I guess they are 20" (19" is the minimum for a nice look on X350 and a good compromise in terme of comfort; I understand though that you intend to have 20" rims with bigger tyres).
Also important in my opinion is rims that are not too "transparent" when bigger, so not to show disk brakes that are ridiculously small behind. On this regard, the Niche wheels better hide the space behind
I quite like the look of Niche Essen, especially the concave rears.
They have been done on a XF here:
https://www.jaguarforums.com/forum/x...new-xf-118546/
If going for Jaguar wheels, I like the simple 5 spoke design of Cremona or Takoba. I like Sepangs too, and think they would look good on your car.
I like the Niche Surge. I too want to swap my 19's for 20's im looking at the Niche Surge, Citrine and Gianelle Yerevan
Offset question. I hate wheels that tuck in too much inside the fender and I hate wheels that stick out of fender. I want to line the wheels up perfectly with the fender what is the perfect offset? factory I believe its 49mm
Also do you guys recommend a staggered setup?
Marque just get the dam Niche and show me the way
