Just replaced a leaky front DS air shock, still getting air suspension fault
Hi guys ; I just replaced one of my leaking front shocks -- I could hear air escaping from the DS shock, and the PS shock has already been replaced once. So; fitted a new shock to the driver's side, now the car has not sank in 2 days even in cold weather (was dropping in the cold) but I am still getting an "Air Suspension Fault" error. Is there a CATs reset procedure ?
Disconnected the battery for a couple of minutes, but maybe I need to do that longer. I remember someone also saying that the car had to be lifted with all wheels off the ground for a reset somewhere, but that might not be the case.
I would recommend all Jaguar owners to purchase a code reader specific for Jaguar. I have an Icarsoft 930. It works great and costs less than $150.00. Check the air lines that connected to shocks again with soap. 1. There is a small O ring that can easily get crushed or not tighten properly during installation. Harbor fright had a complete assorted O rings set for $15.00. 2. You might want to rebuild your air compressor as well. Its very easy project and there are bunch on ebay for sale.
Xeno (08-30-2021)
Will try the soapy water trick, thanks for the tips !
+1 on the code reader. The iCarsoft 930 can reset the air suspension fault codes. If the car hasn't dropped after replacing the shock, reset the code and see what you get. I'm assuming you have an X350 or X358 model.
Thanks, looks like a good excuse to buy some more tools which I don't mind hahaha. Is there no other way to reset the air suspension fault codes? Im assuming pulling the battery cables doesn't do anything. Yes I have an x350 - 2004 xj8
Well, I tried the soapy water trick and didn't find anything that resembled a leak - but i'm wondering if it should be done at a specific time? Had cold weather last night, and the front end is sitting low again ; so apparently the system is loosing pressure from somewhere still. Tightened the top connections, seemed like they did both tighten up a bit more on the lower half of the air line assembly (lower brass fitting). It wasn't sitting so low that it looked UN-driveable, as it has been previously. Low suspension warning light comes on only after about 30-40 seconds of the compressor kicking in.
etaent
08-30-2021 10:24 AM
hawaiianjag
63
07-24-2014 04:52 AM
Xcellr8
05-24-2014 12:30 PM
H20boy
General Tech Help
10-31-2010 08:27 PM
steffenvh
01-10-2010 11:45 PM
