Kasuga on XJ X358 ??
I've got 10.5" wide ET49 (295/30 tyre) wheels on the back of mine which fit, just. Part of the inner wheel arch liner had to be trimmed away to allow the inside to fit, based on a 10" ET46 which is the spec of the kasuga they would protrude 8mm more than my wheels and have more room on the inside, based on a 275/35 tyre as per the X351, so I would suggest that the wheels would fit, and I've seen an X350 with the Matiava wheels from the X351 also which fitted as a staggered set up. I'd recommend a 285/30 tyre if you're going down the staggered route though.
But if you can get them, I'd agree with Alec and suggest 4 wheels the same size, unless you're looking for a specific look. But 20mm H&R spacers can be fitted to the rear to achieve the same effect, see JIM64's posts as he's just fitted spacers.
