keep getting the same code for O2 sensor
i have a 2006 XJ8 L and i have replaced the up stream #2 O2 sensor bank #1 twice, and the check engine light comes back on within a week with the same code. i have been using Bosch made sensors, and Jag uses Denso at the factory.. Could that be the reason? Does anyone have any other ideas as to what could be causing this to happen?? should i replace it again with a Denso?? could the computer be going bad?? the wiring has been checked and it is fine.. no exhaust leaks and the cat is NOT clogged. so i am out of ideas......................HELP!!! please..
Bigvettefreak (10-15-2015)
Bigvettefreak (10-16-2015)
Upstream, Sensor 1, before the cat
Downstream, Sensor 2, after the cat
Before/after is in relation to the direction of the exhaust flow
Actually which code do you have? You first said P0137, but then you said P0131
P0137 = downstream sensor, after the cat
P0131 = upstream sensor, before the cat
Which sensor did you change?
The following 3 users liked this post by Cambo:
okay i spoke with my mechanic and he said that i had given him Both sensors for bank 1 and he replaced them both, sensor 1 & 2 bank 1. so i should be fine, but i keep getting the ck engine light and the P0137 code he is at a loss to explain this problem as well. Thank you for being patient with me..
The following 2 users liked this post by caldoofy:
Bigvettefreak (10-22-2015),
Don B (10-22-2015)
i spoke with the mechanic and he said he checked everything and he did not see anything wrong with the wire harness. so he changed the front sensor thinking that maybe one old and one new sensor was an issue.. but the light came back on with the same P0137 code again.. i don't think it is the sensor either, but some where in the harness, he just has to find it. i am broke and have to wait until i can afford to take it back to him and let him get into the harness again.. the light has stayed off much longer this time..
Received 12,941 Likes
caldoofy (10-23-2015)
Bigvettefreak (10-24-2015),
Don B (10-31-2015)
thank you to you all for your help.. don't know what i would do with out you,..
![Icon Goofygrin](https://www.jaguarforums.com/forum/images/smilies/icon_goofygrin.gif)
