Knock & Rattle: Connecting Rod
Received 13,206 Likes
Connecting Rod
It was a beautiful day in most of Tennessee today, but not in our driveway.
In preparation for manually rotating the engine so I could inspect for what I had begun to hope was a broken valve spring, I removed the coils and plugs from Bank 2. I disconnected some coolant hoses and removed the reservoir for better access.
I disconnected the supercharger belt and spent some time listening with my stethoscope as I spun the pulley. The S/C was definitely not the source of the engine noise.
Access to the bolt that secures the harmonic balancer to the crank is obstructed by a couple of rigid pipes (high pressure A/C lines probably - I didn't take the time to identify them). Working by feel alone, I found that a 24mm socket fit the bolt. I fitted a short extension and ratchet and slipped a long curtain rod tube over the ratchet handle for better leverage and control.
I wanted to establish TDC on cylinder 1 so I could tell when I had rotated the engine through two full rotations, to be sure I inspected all the valve buckets at the point when they were in their highest positions (valves fully closed).
I inserted a long wooden dowel in the cylinder 1 spark plug hole until its end rested on the top of the piston. I then rotated the engine and watched the dowel rise. When it just began to descend from its highest point, I made a mark on the dowel to indicate TDC. I used one of the air spring studs as a reference point for my TDC mark.
Once I had cylinder 1 at TDC, I thought to myself, I may as well rule out a connecting rod/bearing problem before I begin checking the valves. Here's the result:
Considering my options. Opinions welcome.
Cheers,
Don
Cheers,
Don
The following 7 users liked this post by Don B:
AD2014 (05-20-2022),
chris-jag (10-05-2018),
EssOess (05-19-2022),
MountainMan (05-25-2022),
paydase (03-19-2017),
and 2 others liked this post.
Don B (03-18-2017)
I didn't check any of the other cylinders because I knew what cylinder 1 was telling me, and I decided I needed to take a break, watch some basketball and think.
Maybe tomorrow I'll check other cylinders to see what they tell me.
Does anyone know if a bottom end job can be done on an X350 without pulling the engine? I have an engine support bar so I could drop the subframe. I'd prefer to avoid pulling the engine if possible for a variety of reasons, not the least of which is that I've been on the lookout for a Super V8 to replace this XJR. So I'd like to do a proper repair but not go overboard on a full engine rebuild, which would be hard for me to resist if I pull the engine, and then I won't want to part with the car for another 100K miles.
The one major unknown is the condition of the crank, which would absolutely have to be reusable since it's NLA from Jaguar and would probably cost more than the car is worth anyway.
Cheers,
Don
The following 3 users liked this post by Don B:
quote Mercedes Benz Techs,
ended up replacing the engine, could not find bearings from jaguar, so I Asume big end ,
the reply was dated 2 weeks ago ,
When I saw this vidio a wile back this reply did not exist and I figured it was a failed gudgon/piston .
Il bet the crank needed grinding , and he was searching for undersize bearings,
In which I doubt there will be a brilliant selection , speculation I know ! But
From what I've seen if the crank is scored in these engines then the engine is toast , unless you have deep pockets or find a good spair crank .
And I believe the S/C crank is heavier duty than N/A
I think a second hand engine will be the most cost effective route ,
Ether way , with this happening to a few people including your self , now I'm thinking I should rap my STR up in a blanket and put it away for safe keeping .
Don B (03-19-2017)
#28
Don, very sorry that you are having this problem. You have been so helpful to everyone on this forum and I know I speak for all when I say that we feel your pain and wish we could help. No matter which end of the connecting rod the slack is coming from, it adds up to a big repair. I'm interested to hear if this job can be done from the bottom with the engine in the car.
Don B (03-19-2017)
#31
Don B (03-19-2017)
Don B (03-19-2017)
#33
Thanks for your kind words, guys.
Obviously, I'd like to find an easier and less expensive solution than a replacement engine, in part because I did an engine swap for a friend last fall and it really wore me out. The real problem was that the donor vehicle was from upstate New York and the undercarriage rust was so bad that every fastener was seized. I had to literally cut out the front 4WD components with a Sawzall in order to remove the engine, and it was no fun at all. But I can't argue that a donor motor may be the fastest and ultimately easiest and possibly even cheapest route to get this car back on the road. A motor already removed from the car would certainly save me time.
Studying the EPC, the pistons on the S/C cars are different but the block and crank appear to be shared with the N/A cars. I don't know if that will open up any options. I'd still be looking at a complete bottom end rebuild at the minimum. No suitable cranks listed on eBay, but why are so many X-Type cranks listed for sale???
I haven't checked to see which years of XJ and S-Type S/C engines are compatible with our '04. Does anyone know off the top of your head?
I really don't have time to focus full-time on repairing this car, so I'm thinking through options for acquiring another vehicle to take the pressure off of this project. Unfortunately, just two weeks ago I sold our mechanically-excellent '93 VDP to a friend, or I could have just driven that for awhile.
Searching online last night I saw a really nice '03 X308 at 110K miles asking a fair price, and I know most of the scary potential failures to use as negotiating points...
I have another idea: a friend has an "extra" '96 X300 that I recently brought back to life after it sat idle for a year (his diagnosis was fuel pump and they had the tank partially out, but it turned out to be a combination of electrical issues and failing CKPS). For many years it belonged to one of our mutual friends, a record producer who was also the long-term owner of an XJS V12. The '96 needs a good tuneup, front shock top bushings, transmission fluid flush and some other TLC. I'm thinking I might propose that if he'll let me drive it for a month or so while I repair the XJR, I'll do the work on his car at no cost to him. Does that seem like a fair trade?
Cheers,
Don
Cheers,
Don
Don B (03-19-2017)
#35
Don B (03-19-2017)
#36
Don, heard about your misfortune thought I'd check your post.
You can only use a 4.2L crank in your car. The difference between the 4.0L and the 4.2L is the stroke. The rods are longer and the crank is redesigned or the pistons would hit the head with the longer rod.
I don't know if its been done but I think you can put a complete 4.0L block jn you car, your car would be a 4.0 instead of a 4.2. My 2000 xk8 has the oposite engineering., a 4.2 in a 4.0 car. Of course the block you get will need to be S/C. ,
Just a couple of thoights, good luck
Bob
Bob
Don B (03-19-2017)
#37
Here are all of the used engines available in the US at auto parts recyclers...
Results sorted by GRADE (Click on heading to re-sort)
Distances are in miles approximate from "06066" postal code.
Click back to modify your previous choice.
Most prices do not include extended warranties or shipping.
2004 Jaguar XJR (1998 to 2007)
Engine
Click Here to see All Interchange Choices
Click Here to see Non-Interchange Choices
Year
Part
Model Description Miles Part
Grade Stock# US
Price Dealer Info Dist
mile
2005
Engine Assembly
Jaguar XJ8 BLACK (PRICED WITH SPRCHRGER) 42,000 A S1256 $3000.09 Brims Import Auto USA-OH(Kenton) Request_Quote 1-800-221-3874 Request_Insurance_Quote
585
2004
Engine Assembly
Jaguar XJ8 BLK, 49K, (4.2L), XJR (SUPERCHARGED OPTION), (VIN B, 8TH DIGIT) 49,417 A H16316 $2950 Bill's Used Parts Inc. - PRP-MA, VARA USA-VA(Christiansburg) Request_Quote 877-917-5470 Request_Insurance_Quote
535
2004
Engine Assembly
Jaguar XJ8 124K W/ SUPERCHARGE 124,572 A U183P $2800 East Coast Auto Source VARA USA-VA(Moneta) Request_Quote 1-800-869-0655 Request_Insurance_Quote
497
2005
Engine Assembly
Jaguar XJ8 W/SUPERCHARGER, 32373.MILES [EXCH] 32,373 A 150607B $2710 Diamond Auto Parts - PRP Midwest USA-WI(Fond-duLac) Request_Quote 1-888-236-7731 Request_Insurance_Quote
825
2004
Engine Assembly
Jaguar XJ8 AOD,RWD,88K,COULD NOT START,BAD ELECTRICAL PROBLEM,COMPLETE W/TURBO 88,622 A 00041283 $2485 American and Import Auto Parts - PRP Midwest MWRP USA-MI(Sterling-Heights) Request_Quote 1-888-839-3799 Request_Insurance_Quote
542
2005
Engine Assembly
Jaguar XJ8 GRN, 90K, (4.2L), W/SUPERCHARGED OPTION, XJR, (VIN B, 8TH DIGIT) 90,593 A J00617 $2450 Bill's Used Parts Inc. - PRP-MA, VARA USA-VA(Christiansburg) Request_Quote 877-917-5470 Request_Insurance_Quote
535
2004
Engine Assembly
Jaguar XJ8 PRICED LESS SUPERCHARGER 77,000 A P94378 $2075 I-80 Auto Parts Co., Inc. MWRP USA-IN(Gary) Request_Quote 1-866-480-7278 Request_Insurance_Quote
771
2004
Engine Assembly
Jaguar XJ8 05/03,LESS SUPERCHARGER ncb 148,700 A G10360 $2035 Lewisville Motor Company - PRPMA, PRP USA-NC(Winston-Salem) Request_Quote 1-800-722-6711 Request_Insurance_Quote
579
2004
Engine Assembly
Jaguar XJ8 XJR (1998 to 2007) XJR,4.2L,AT,CNOTES 125,000 A S03031 $2000 Calton's Cars and Parts USA-MD(Elkridge) Request_Quote 410-799-1320 Request_Insurance_Quote
289
2004
Engine Assembly
Jaguar XJ8 XJR (1998 to 2007) SHELF-4.2L,110K,TESTED,RUNS NICE 110,563 A 14I337 $2000 Advanced Auto Recyclers USA-MI(Southfield) Request_Quote 248-353-5353 Request_Insurance_Quote
556
2005
Engine Assembly
Jaguar XJ8 XJR (1998 to 2007) 4.2,AT,75K,RAN GREAT,-HARNESS,-LHCVR 75,538 A E6L183 $1895 Eiss Brothers Auto Parts, Inc./ Fenix Parts Inc. USA-NY(Watertown) Request_Quote 1-800-698-3477 Request_Insurance_Quote
228
2004
Engine Assembly
Jaguar XJ8 XJR (1998 to 2007) 12/03, SUPERCHARGED 63,752 A 018004 $1850 Brickyard Imported Cars USA-IN(Brooklyn) E-mail 1-800-247-9273 and 1-317-831-2627 745
2004
Engine Assembly
Jaguar XJ8 w/Supercharger-95K 95,000 A TXJRENG $1800 Dynamic Auto Parts USA-MI(Detroit) Request_Quote 313-646-2474 Request_Insurance_Quote
552
2004
Engine Assembly
Jaguar XJ8 XJR (1998 to 2007) 4.2,AT,97K,RAN 97,774 A E6E833 $1795 Eiss Brothers Auto Parts, Inc./ Fenix Parts Inc. USA-NY(Watertown) Request_Quote 1-800-698-3477 Request_Insurance_Quote
228
2005
Engine Assembly
4.2L SUPERCHARGED RAN STRONG 108,316 A 110116 $1750 Euroline Auto Dismantling USA-CA(Rancho-Cordova) Request_Quote 916-861-4343 Request_Insurance_Quote
2550
2004
Engine Assembly
Jaguar XJ8 90 DAY STANDARD WARRANTY! 117,000 A 13239 $1500 Eastern Automotive Inc. USA-NC(Four-Oaks) Request_Quote 1-919-934-4101 Request_Insurance_Quote
549
2004
Engine Assembly
Jaguar XJ8 97K, 6 MONTH PART WARRANTY, RUNS NICE, W/SUPERCHARGER 97,000 A H08024 $1499.44 Nationwide Auto Recycling USA-MA(Lancaster) Request_Quote 1-866-534-0477 Request_Insurance_Quote
59
2005
Engine Assembly
Jaguar XJ8 (4.2L), supercharged option, XJR 125,000 A W1566 $1400 Wright's Auto Parts USA-RI(Foster) Request_Quote 401-647-1700 Request_Insurance_Quote
38
2005
Engine Assembly
Jaguar XJ8 SUPER CHARGED, OFF READY-98000 98,000 A 05JAG $1300 Old Yeller Auto USA-CO(Denver) Request_Quote 303-295-3952 Request_Insurance_Quote
1696
2004
Engine Assembly
Jaguar XJ8 86K W/SCH 170-180 COLD COMPRESSION, NEEDS RH VALVE COVER 86,000 A Q0691 $1200 Strandberg Auto USA-WI(Centuria) Request_Quote 1-800-448-5121 Request_Insurance_Quote
1033
2004
Engine Assembly
Jaguar XJ8 Runs great!,140k 1 A 00011295 $1200 Bone Yard USA-CO(Denver) E-mail 1-303-295-3534 1696
2004
Engine Assembly
Jaguar XJ8 XJR (1998 to 2007) "R",4.2L,MFI TESTED 128,695 A 010735 $Call Allen's Used Auto Parts USA-FL(Tampa) Request_Quote 813-620-4242 Request_Insurance_Quote
1112
2004
Engine Assembly
Jaguar XJ8 XJR (1998 to 2007) 4.2,AT 81,589 A 5189 $Call J.C. Recycling, Inc. USA-CT(Meriden) E-mail 1-888-247-1199 26
2004
Engine Assembly
Jaguar XJ8 4.2L--134K 134,000 A A1055 $Call Epic Auto Dismantling USA-CA(Littlerock) Request_Quote 661-480-7822 Request_Insurance_Quote
2494
2005
Engine Assembly
Jaguar XJ8 89,123 A 00000082 $Call Alpine Foreign Auto USA-OK(Goldsby) Request_Quote 405-288-0104/844-357-7326 Request_Insurance_Quote
1426
2005
Engine Assembly
Jaguar XJ8 111,000 A 131148075 $Call Galaxy Used Auto Parts, Inc USA-CA(Sun-Valley) E-mail 818-767-9494 2524
2004
Engine Assembly
Jaguar XJ8 4.2T, (-TRB/EMAS) 214,000 C DA042 $1925 Don's Automotive Mall/Fenix Parts Inc. USA-NY(Binghamton) E-mail 800-283-3667 / 607-775-1542
174
2004
Engine Assembly
Jaguar XJ8 4.2T, (-TRB/EMAS) 214,000 C DA042 $1925 Don's Automotive Mall Pennsburg / Fenix Parts Inc. USA-PA(Pennsburg) E-mail 215-679-8270 / 866-366-7227
186
2005
Engine Assembly
Jaguar XJ8 GOOD TESTED LOW MILES RACK $3000 M & S Auto Salvage USA-CA(Whittier) Request_Quote 562-693-7777 / 562-945-3511 Request_Insurance_Quote
2515
2005
Engine Assembly
Jaguar XJ8 (4.2L), supercharged option, XJR, (VIN B, 8th digit) TESTED 1890 $2800 American Dismantling Inc. USA-CA(Fontana) Request_Quote 1-800-527-2739 Request_Insurance_Quote
2482
2004
Engine Assembly
Jaguar XJ8 SUPERCHARGED W $2800 Lynwood Auto USA-CA(Lynwood) Request_Quote 1-310-763-0509 Request_Insurance_Quote
2525
2004
Engine Assembly
Jaguar XJ8 XJR (1998 to 2007) W 321,GET CORE 130207 $2250 Jones Auto, Inc. USA-IN(Orleans) Request_Quote 812-865-4161 Request_Insurance_Quote
769
2004
Engine Assembly
Jaguar XJ8 (4.2L), XJR (w/supercharger opt), (VIN B, 8th digit),4.2L 82K-0MI A00359 $1850 Eco Green Auto Parts USA-GA(Atlanta) Request_Quote 404-752-8886 / 404-892-9090 Request_Insurance_Quote
860
2004
Engine Assembly
Jaguar XJ8 XJR (1998 to 2007) 4.2,FLR,6AT,RWD,-321 GFJ712 $1700.97 B & R Auto Wrecking - Tacoma USA-WA(Tacoma) Request_Quote 888-752-1118 Request_Insurance_Quote
2456
2004
Engine Assembly
Jaguar XJ8 COMPLETE Q327 $1700 Southern Imports USA-NC(Grover) Request_Quote 1-800-522-4787 Request_Insurance_Quote
669
2004
Engine Assembly
Jaguar XJ8 XJR (1998 to 2007) 15177 $1500 Amigo Used Auto Parts USA-NJ(Newark) Request_Quote 973-824-2222 Request_Insurance_Quote
118
2005
Engine Assembly
Jaguar XJ8 3 05,RWD,MFI,4.2,AT 16227 $1500 Robert Halls Auto Salvage USA-MS(Long-Beach) Request_Quote 228-868-4001/ 888-357-4194 Request_Insurance_Quote
1221
2004
Engine Assembly
Jaguar XJ8 LS4513 $Call Lone Star Imports Used Auto Parts, Inc. USA-TX(Houston) Request_Quote 1-888-919-5151 Request_Insurance_Quote 1518
2004
Engine Assembly
Jaguar XJ8 SOLD SUPERCHARGER LS4950 $Call Lone Star Imports Used Auto Parts, Inc. USA-TX(Houston) Request_Quote 1-888-919-5151 Request_Insurance_Quote 1518
2005
Engine Assembly
Jaguar XJ8 (4.2L), supercharged option, XJR, (VIN B, 8th digit),4.2L-0MI MY280605 $Call Bill Dee's Auto Salvage USA-TX(Houston) Request_Quote 713-694-9696 Request_Insurance_Quote
1524
2004
Engine Assembly
Jaguar XJ8 XJR (1998 to 2007) XJR/ENGINE ASSM/CK 121213 $Call Nica Motors, Inc. USA-TX(San-Antonio) Request_Quote 1-877-788-6888 Request_Insurance_Quote
1692
2004
Engine Assembly
Jaguar XJ8 007870 $Call A Plus Auto Parts USA-TX(Pasadena) Request_Quote 1-866-278-7055 / 1-713-477-1000 Request_Insurance_Quote
1518
2005
Engine Assembly
Jaguar XJ8 NS $Call Galaxy Used Auto Parts, Inc USA-CA(Sun-Valley) E-mail 818-767-9494 2524
2004
Engine Assembly
Jaguar XJ8 4.2L,AOD,04/04,MFI 028723 $Call Widewater Auto Parts USA-VA(Stafford) Request_Quote 540-659-6800 Request_Insurance_Quote
350
2004
Engine Assembly
Jaguar XJ8 (4.2L), exc XJR; (VIN C, 8th digit), CAL emissions-75K 75,000 G15349 $2000 Eagle International Used Auto Parts USA-FL(Miami) E-mail 305-884-0565/305-592-2520 1194
2004
Engine Assembly
Jaguar XJ8 (4.2L), XJR (w/o suprchrgr opt)-84K 84,000 G19264 $2000 Eagle International Used Auto Parts USA-FL(Miami) E-mail 305-884-0565/305-592-2520 1194
2004
Engine Assembly
Jaguar XJ8 04 XJR SUPERCHARGED ENGINE, RUNS GOOD, LESS SUPERCHARGER 122,000 1080 $1850 European Automotive Group, LLC USA-GA(Moultrie) Request_Quote 229-890-0050/800-761-3876 Request_Insurance_Quote
967
2004
Engine Assembly
Jaguar XJ8 4.2 TURBO 72K MILES RUNS GREAT. SEARCH 2-15127 ON YOU TUBETOSEE ENG RUNNING IN CAR-0MI 2-15127 $Call South Florida Auto Recycling #2 USA-FL(Ft.-Lauderdale) Request_Quote 954-318-7888 Request_Insurance_Quote
1170
Year
Part
Grade Stock# US
mile
OR
Request a Quote from hundreds of recyclers
Mechanical Part Grading A = Less than or equal to 60k miles, or greater than 60k miles but less than or equal to 200k miles and less than or equal to 15k miles per year B = Greater than 60k miles and less than or equal to 200k miles but greater than 15k miles per year C = Greater than 200k miles
Part Grading Abbreviations Downgrade = Recycler choose to downgrade the part based on damage not reflected in the grading algorithm
Engine
Year
Part
Grade Stock# US
mile
2005
Engine Assembly
585
2004
Engine Assembly
535
2004
Engine Assembly
497
2005
Engine Assembly
825
2004
Engine Assembly
542
2005
Engine Assembly
535
2004
Engine Assembly
771
2004
Engine Assembly
579
2004
Engine Assembly
289
2004
Engine Assembly
556
2005
Engine Assembly
228
2004
Engine Assembly
2004
Engine Assembly
552
2004
Engine Assembly
228
2005
Engine Assembly
2550
2004
Engine Assembly
549
2004
Engine Assembly
59
2005
Engine Assembly
38
2005
Engine Assembly
1696
2004
Engine Assembly
1033
2004
Engine Assembly
2004
Engine Assembly
1112
2004
Engine Assembly
2004
Engine Assembly
2494
2005
Engine Assembly
1426
2005
Engine Assembly
2004
Engine Assembly
174
2004
Engine Assembly
186
2005
Engine Assembly
2515
2005
Engine Assembly
2482
2004
Engine Assembly
2525
2004
Engine Assembly
769
2004
Engine Assembly
860
2004
Engine Assembly
2456
2004
Engine Assembly
669
2004
Engine Assembly
118
2005
Engine Assembly
1221
2004
Engine Assembly
2004
Engine Assembly
2005
Engine Assembly
1524
2004
Engine Assembly
1692
2004
Engine Assembly
1518
2005
Engine Assembly
2004
Engine Assembly
350
2004
Engine Assembly
2004
Engine Assembly
2004
Engine Assembly
967
2004
Engine Assembly
1170
Year
Part
Grade Stock# US
mile
OR
Don B (03-19-2017)
#38
Yes, I knew a 4.0L crank wouldn't work - the question was whether the cranks were different between the 4.2L S/C and N/A engines. Based on a quick review of the EPC, it appears the same cranks were used in both the S/C and N/A engines, and no difference in the cylinder blocks is shown, but the pistons are different.
Cheers,
Don
#39
#40
The crank part # AJ89617.
List of
Fitment/Applications
Jaguar S-Type 4.2L V8 A/T Base 2003, 2004
Jaguar S-Type 4.2L V8 A/T R 2003, 2004
Jaguar S-Type 4.2L V8 Base 2006, 2007, 2008
Jaguar S-Type 4.2L V8 M/T Base 2003, 2004
Jaguar S-Type 4.2L V8 R 2005, 2006, 2007, 2008
Jaguar S-Type 4.2L V8 Sport 2005
Jaguar S-Type 4.2L V8 VDP Edition 2006
Jaguar XF 4.2L Base 2010
Jaguar XF Luxury 2009
Jaguar XF Premium Luxury 2009
Jaguar XF Supercharged 2009
Jaguar XJ8 Base 2004, 2005, 2006, 2007, 2008, 2009
Jaguar XJ8 L 2005, 2006, 2007, 2008, 2009
Jaguar XJR Base 2004, 2005, 2006, 2007, 2008, 2009
Jaguar XK Base Convertible 2007, 2008, 2009
Jaguar XK Base Coupe 2007, 2008, 2009
Jaguar XK8 Base Convertible 2003, 2004, 2005, 2006
Jaguar XK8 Base Coupe 2003, 2004, 2005, 2006
Jaguar XK8 Victory Edition Convertible 2006
Jaguar XK8 Victory Edition Coupe 2006
Jaguar XKR Base Convertible 2003, 2004, 2005, 2006, 2007, 2008, 2009
Jaguar XKR Base Coupe 2003, 2004, 2005, 2006, 2007, 2008, 2009
Jaguar XKR Portfolio Convertible 2008, 2009
Jaguar XKR Portfolio Coupe 2008, 2009
Jaguar XKR Victory Edition Convertible 2006
Jaguar XKR Victory Edition Coupe 2006
Now you have a couple of options.
If you get a replacement crank you will probably need all new bearings. If you get your crank machined you can get by with needing only bearings for that journal.
List of
Don B (03-20-2017)
