The last word on key programming...
Can I program a new key for my 05 Super V8 using the posted procedure on this forum without going to a dealer or not?
I have read conflicting posts and received conflicting info from techs and dealers. I have gotten the new key CUT by a locksmith that had the special TIBBE cutter, but told me that a special Jaguar programming computer was required to make it work with the ignition security system. I was told that there are two separate security systems inside the key, one to start it and a separate one to unlock the doors.
I don't want to just try the programming procedure because I'm afraid I might erase my working (original) key. Is anyone on here really sure about this??
Jeff
Jeff
I bought a used fob from Ebay and used that as second key and went thru the programming sequence as detailed in this forum and after about the sixth attempt had two working fobs.
I simply tansferred the guts from the used fob into my broken fob.
I believe it works with less than two keys if you're programming the remote access chip (the one that has the battery), but all the info I've seen says for programming the transponder chip (which is in the smaller top part of the fob with the Tibbe key, not the big bit with the buttons and the battery) you need two already programmed to the car.
All I know is that I have two key fobs that operate remotely as well as all functions including starting the car. I originally had two working fobs and one just stopped working.
I changed batteries, cleaned contacts no joy.
Bought a used one same frequency on Ebay and swapped the board from that into my broken fob and went thru programming sequence as detailed in this forum.
I was getting a little frustrated as the programming sequence was not working to begin with. Once I got the speed of the procedure down it eventually worked. You have to be quite fast.
I even did it again to see if I could get the broken board to reprogram but could not.
If I understand John's post correctly he 'reused' the transponder from his original key fob and just replaced the wireless powered portion from the Ebay donor fob.
This seems consistent with Patrick the Cat's observation that if only one key/transponder is available then SDD is required.
John only had to get the car to recognize the wireless powered portion (the remote), not the already recognized transponder.
WW
WW
Hi John;
The battery powered PCB is only the wireless remote circuit (locks and unlocks doors, trunk without having to insert the key). This remote is what you are teaching the car to recognize with the procedure you used. This portion is not sufficient to enable PATS to start the engine.
If you look to the left of the tibbe key in your photo you will see a translucent tubular object with an internal coil. This is the transponder. It is a passive circuit not requiring a directly connected power supply. The transponder is electrically stimulated and then sensed by a circuit located in or near the ignition switch. This is why a recognized transponder must be in sense range for the car to actually start. There is brief mention in the "2004 XJ Technical Manual", pp 166, 170.
I don't recommend doing it but you could remove the transponder from your fob and then attempt to start the car to prove it is a necessary requirement.
Best Regards, William
jackra_1 (01-15-2019)
Hi John;
I was incorrectly under the impression that everything electrical was on that circuit board! Live and learn.
It's the Jaguar equivalent of the I/D microchip that you can have injected into your cat or dog's neck.
Without it, or with one not registered with the car's system the Tibbe will still turn all the way, and apparently all the lights on the dash will come on as normal, but when you turn the key to start ... nothing happens.
That's the badger !
Yes, 'though I've never done it myself. It's the only way if you have only one (or no) key with a transponder already registered.
However, if you have two keys with registered transponders (and the correct Tibbes of course) then there is a procedure where you put the good ones in, one after another (and do 'something') and then the new one you want to register.
However, I think the SDD is the only way to delete/deregister a transponder, eg if you loose a key.
Fobs can be programmed with out another fob, did it.
It takes two, programmed keys, to start with though.
Was not very happy about that, as a key needed bought, cut, & then programmed.
Had a new set of codes set, so any old keys would not work.
If i must pay, might as well get the most i can for my money.
After the second key; programmed, you can program as many as eight, if memory serves, yourself.
That's more than i have keys, or any need for.
YES ! You can program a third transponder if you already have two that work. That's what we said above, but you can't program a second TRANSPONDER on the car if you only have one that works; if that's all you have then you need an SDD plugged into the data port.
Simple programming on the car with only one good key - Remote chips YES, transponders NO.
Jeff
Jeff
Best Regards
Jeff
