leaking trans--harness?
My trans has developed a slow drip, occasionally leaves a drop on the garage floor. From what I can tell it's leaking from the little 2-wire box/harness that's on the right rear corner (behind the fill plug). Is this the infamous leaking harness?
What part do I need to get to replace this?
Figure it will be time for a fluid and filter change (67k miles) so timing is good for this problem (if there could be such a thing). I've bookmarked some other threads on the trans fluid change. Am I correct that some folks have used Valvoline or some other brand synthetic ATF with no issues on this ZF box?
Thanks,
-Michael
Thanks,
-Michael
The connector is a common source of the leak and I replace them often.
http://www.thectsc.com/images/pdf/th...eplacement.pdf
I use ZF Lifeguard 6 Transmission Fluid but people use whatever they want.
If after contaminating the system with different fluid you experience the 'bark/squeak' or other shift anomalies, you will know what caused it.
On the other hand, you will save maybe a hundred dollars using alternate fluids.
All sorts of opinions but that is what makes a forum.
bob gauff
bob gauff
Thank you! That's very helpful info.
I'll have to look again, that 15 pin round connector is not what I saw on the back of my trans. What I was looking at was 2 wires and a square connector. But definitely on the rear right of the trans, in the spot that round connector is supposed to be. Or maybe I need to look up higher. Is there a smaller harness under the big round one?
So the sleeve is what I need to replace, the rest of the valve body/harness connector is kept?
I'll probably stay with the OE fluid just because I don't want to do this job again.
Yes but only with the pan removed. So do it with the fluid/pan change.
As Bob's pictures show there is a white plastic tab on the valve body (Mechatronic is what ZF calls it). This allow the sleeve to be pulled out from the outside once the wire harness is unscrewed. I have found just unscrewing the harness is pretty hard too and it's plastic.
Pristine97XK8Convertible
04-28-2017 11:08 AM
