Left Rear Window (2005 XJ8VP)
Old 06-15-2023 | 06:22 PM
benzjag's Avatar
Default Left Rear Window (2005 XJ8VP)
The left rear window on my 05 XJ8 will go down/up maybe 3 inches then stop. I have to keep pressing the switch several times before it will even move, but when it does, it's just a few inches! I am guessing the motor and/or regulator? Any ideas? PS Both switches (driver's & rear door) do the same! It will not move at all in the auto, but will in the "manual" position.
Thanks!
Richard
Old 06-16-2023 | 04:16 AM
h2o2steam's Avatar
Before hunting for a hardware problem, try retraining them. Sounds like they have lost their stored upper and lower limits.
https://www.jaguarforums.com/forum/x...esolved-78271/
If that doesn't sort it, then you might have a guide track that is creating excessive friction and the window motor is tripping an over current protection.
Old 06-16-2023 | 02:31 PM
Thomas-S.'s Avatar
It does not sound like a retraining problem to me, because in that case the windows would go up and down manually all the way without stopping. As they only move about 3 inches and then stop, it looks like another problem to me,either electronic, or mechanical.
With both switches showing the same response, I would try to have a look at the mechanism.
Best regards,
Thomas
2003JagStr
11-20-2022 08:17 PM
adenshillito
11-09-2022 09:23 AM
Tomwhite
01-28-2021 07:52 AM
usaf
12-10-2016 01:06 PM
CEBXK8
12-17-2007 06:58 PM
Quick Reply: Left Rear Window (2005 XJ8VP)
