LH repeater
Old 02-25-2019 | 01:42 PM
milhunkcj's Avatar
Question Location LH repeater
I have a 2004 XJ8 looked up repeater for LH turn signal it said front fender, but where. Is it in headlight assembly? What does it look like also I see numbers next to fuses in fuse boxes is there a place to find out what number goes to what. Thanks have a great day
Old 02-25-2019 | 03:42 PM
mhamilton's Avatar
There is a turn signal bulb in the parking light/high beam assembly up front. There is also a side turn signal indicator that will be in the fender at the front of the door rub moulding (spear).
The fuse number circuit list is in your owner's manual. There's 3 fuse panels in these cars, underhood, in passenger kick panel, and in the trunk.
The following 2 users liked this post by mhamilton:
AD2014 (02-27-2019), Don B (02-26-2019)
Old 02-25-2019 | 08:09 PM
milhunkcj's Avatar
Question LH repeater
I have a 2004 XJ8. My manual said its in front fender, and what does it look like, where in front fender is it located. In your fuse boxes fuses are numbered. is there a chart or list that tells you what number goes to which device or part. thanks have a great day.
Old 02-26-2019 | 01:31 AM
Don B's Avatar
Hi milhunkcj,
The turn signal repeater lamps are just ahead of the front doors and continue the line of the door side molding strip. If your left repeater does not illuminate when the left turn signal is on, switch your right turn signal on and look at the right fender. The lamps in the sides of the front and rear bumper covers are called the sidemarkers.
I believe the fuses are identified in the Owners Manual (Driver's Handbook). If you don't have one for your car, you may be able to find a printed copy on eBay or possibly a pdf download from the Jaguar TOPIx website.
The fuses are also identified in the Electrical Guide, but on individual schematics rather than in a convenient list. You can download the Electrical Guide here:
Jaguar X350 Electrical Guide 2004
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (03-08-2019), AD2014 (02-27-2019)
Old 02-26-2019 | 05:34 AM
EsRay's Avatar
Don't know if this is any help but I attach for a 2005 XJ8?
Shows F9 ATO 10A Red - Left-hand direction indicator and repeater
In the passenger kick panel fuse box?
File Type: docx
Don B (02-26-2019)
Old 02-26-2019 | 01:28 PM
Don B's Avatar
Hi again, milhunkcj,
I have merged your two threads together into one so that all the replies will be together in one thread. Please do not start any additional threads on this subject since it only leads to confusion and duplicated effort on the part of others who want to help.
Cheers,
Don
The following 3 users liked this post by Don B:
93SB (03-08-2019), AD2014 (02-27-2019), milhunkcj (02-27-2019)
Old 02-27-2019 | 10:02 AM
milhunkcj's Avatar
thank you have a great day
cheers (as you say) goodbye from the USA
Chris J. Giles
Old 02-27-2019 | 08:15 PM
milhunkcj's Avatar
thank you very much for the help have a great day.
cheers goodbye
chris giles Pittsburgh, pa USA
Old 02-28-2019 | 10:21 AM
milhunkcj's Avatar
HI EsRay,
Thanks for the fuses location download, Got the file, Both repeater fuses blown, replaced them everything OK.
Thanks again have a great day
Don B (02-28-2019)
plums
10-23-2011 01:51 AM
Bacardi 151
07-27-2011 06:04 PM
Quiet1
06-27-2010 02:14 PM
starvinmarvin08
03-25-2009 04:26 PM
Quick Reply: LH repeater
