Location of the air suspension height sensor
Does anyone knows where the high sensor is located for the air suspension of an XJ8 2004?
I need to replace the front air shocks and I am worry about that. I have been reading other posts and watched the installation video from Arnott in YouTube and they do not mention anything about it. Also the removal and installation looks to easy and I think there is more about it that meets the eye.
What do you mean "high sensor"? On the 2004 you might have one on each side. It attaches to the lower suspension arm and has an arm that attaches to a fixed point to read height. You'll see it when removing the wheel. If you only have one sensor it will be on the driver's side near the brakes toward the vehicle cabin side. I'm a little fuzzy on exact location since I removed it when I installed coilovers on my car.
The lower strut bolt tends to stick, but that's the only real issue I'm familiar with when swapping parts.
Don B (11-16-2016)
Received 12,942 Likes
The best resource I know of is the Air Suspension & ECATS section of the Dealer Training Manual, which you can download here:
http://www.mediafire.com/file/7rdkgg...on_Section.pdf
The ride height sensors are mounted on the suspension control arms and are described and illustrated in the manual. The manual states that there are four height sensors, which was correct for early X350s, but if the VIN of your '04 is G26872 or higher, you will only have three height sensors, one at each rear corner and one at the front left corner.
I have done the Arnott conversion on two X350s and did not have to fiddle with the height sensors at all.
Replacing the front air springs/shocks is straightforward if you follow both the Arnott printed instructions and their YouTube video. Note that the female narrator of the video repeatedly refers to "nuts" as "bolts," but otherwise the instructions are correct. One thing to know is that the air spring/shock units are heavy, so be prepared to handle them when you disconnect the last top nut or lower bolt.
If your car has had certain software updates performed, you will need Arnott's Electronic Bypass Module (EBM) to prevent the Air Suspension Control Module from causing suspension and CATS warning lamps to illuminate on the instrument cluster.
There is plenty of information in this forum on replacing the stock suspension components with Arnott's.
Cheers,
Don
Hi rf69,
Cheers,
Don
Cheers,
Don
The ride height sensor is what I needed to know about more.
Hi rf69,
Cheers,
Don
Cheers,
Don
Erm ... actually the rear height sensors are connected to the upper suspension arms, not the lower
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/400x300/_1_154b4820db3c56a87cc3424dbfb7c131c774d651.jpg)
The following 2 users liked this post by Partick the Cat:
Don B (11-18-2016),
motorcarman (11-20-2016)
Petz (07-17-2023)
AD2014 (11-25-2016)
abonano
86
08-12-2017 07:05 PM
FS[Canada]: Jaguar S Type Suspension/Drive Train
05S-Stype
10-23-2016 04:11 PM
