Location of Ground #32
Don't know and I have had the instrument panel completely out and don't remember seeing it?
I would remove the fabric cover under the drivers side of the dash board and take a look.
I am sure you know but the grounds on this Al. bodied car are VERY fragile!!
It's very common to break off the grounding studs if you try to work on them.
They can be replaced with a bolt and toothed washer. Make sure it bites into the metal good.
The torque on the nuts is super low so a light snug is all that's needed.
I did find one under the hood on the drivers side down by the brake master cylinder. Need to remove the plastic cover over the MC and look at the drivers side inner fender.
Do you have a ground problem?
Silvios
10-23-2012 01:02 PM
hlgeorge
05-05-2010 09:29 PM
