Locked out of Trunk
Locked out of Trunk
Looks like I'm going to be installing my THIRD trunk lock actuator assembly on my 2004 XJ8. When I bought the car in 2015 the motor was making a grinding noise, but having replaced this on my previous car (An X308) If figured it was a cheap easy fix which it was. Called the Jaguar Graveyard guys and got a replacement assembly for $75. Installation was a little fiddly but took less than 20 minutes. It worked great up until a few days ago when the motor stopped drawing down the trunk lid in soft touch mode. I got the TRUNK OPEN warning on the dash and the key fob wouldn't lock the car or set the alarm. It could only be done with the key in the driver's door and then I'd hear the 2 beeps indicating a security system fault. Fast forward to yesterday and neither the fob, trunk release on the dash, button on the lid nor the key under the license plate well would open the trunk. I was 100% locked out of the trunk. Luckily there were no groceries back there to spoil! Being the kind of person that refuses to be beaten by some good-fer-nuthin British car, I devised a solution and found the problem. If this ever happens to you, remove the license plate and drill a hole dead center of the plastic plate recess area (I used a 13/16" drill) and through the outer aluminum skin. Once this is done, you will see the emergency release cable inside the hole. Grab it with a pair of thin needle-nosed pliers and pull upward which will open the trunk. The mistake I made when I installed the actuator the last time is that I in correctly routed the cable which connects the lock cylinder to the latch which made the cable too long disabling the manual unlock function. I pulled out the actuator assembly and reinstalled it correctly so the key now unlocks the trunk but the lid still won't draw down completely. It's most likely that the actuator has again gone bad and will require replacement. I'm going new this time. The part is C2C1740 and is available from the usual suspects for around $200. Cost to get into the trunk - $0, and since the access hole I drilled is hidden under the license plate (I plugged it with a rubber grommet from my local ACE hardware) he intrusion is invisible. Problem solved and lesson learned. I'm sure I'm not the 1st person that this has happened to so I hope that if you're in the same predicament my misfortune will at least help out.
The following 4 users liked this post by Slug:
I heard of a guy that had the same thing happen to him on Christmas eve. The trunk was full of presents that were supposed to go under the tree. Talk about the Grinch who stole Christmas!
These cars certainly have the desire to throw a tantrum at the worst opportune time! Good thing I hadn't been to the fish market!
Here's another thing: Make sure the glow-in-the-dark escape pull is routed 100% correctly, even the slightest bit of tension pulling on the latch mechanism will disable the soft close feature and you'll get the "TRUNK OPEN" warning on the panel.
Oops. Freud must be at work (me being already familiar with this thread, not to mention plain dumb.)
Today, whilst playing around with battery chargers and cables small enough to close the boot/trunk on, I managed to lock my keys in the trunk. I did!
Several minutes of panic. I do have a chainsaw in the garage. Fortunately I found the spare key after settling down to a thinking state.
True. Today.
True. Today.
True. Today.
True. Today.
Start with car locked. Unlock boot. Throw keys in boot. Close boot. Mutter "why did I get up this morning?"
Obviously there were other distractions, but I'm really good at testing "idiot-proofness".
Not to mention another momentary panic...the spare valet key doesn't open the boot. i.e. not directly
tnt
05-23-2022 07:30 PM
Magicland
24
08-03-2017 10:33 AM
two96jags
01-30-2016 05:21 PM
