Locking wheel nut
If you don't mind messing up the lug nut then use a 12 point socket and hammer it on. I removed one off a Lexus using a 21mm if I recall. The right one is trial and error. Removing the socket from the lug nut can be difficult so pick a socket you will not mind roughing up or throwing away.
rsa760041 (10-26-2020)
Pristine97XK8Convertible
06-14-2018 02:11 PM
