Loose brake caliper on rear.
I had to do a brake job on my car today due to abnormal, uneven pad wear. (I discovered I had a problem when the inboard pad wore down on one side to the point it strated grinding against the rotor.)
Upon getting everything put back together, the caliper feels loose, and the little spring clip that goes at the bottom isn't really all that tight.
Anybody have any ideas what's causing this, and what I can do to fix it?
KenXJ
11-05-2022 08:22 AM
Bob Smith
10-18-2011 07:23 AM
