Loose Burlwood Door Trim
Since the metal tab of the wood panel substrate is seen, it is no longer being held by the interference clip, or the clip itself is missing or broken. You'll have to remove the wood panel and look for the missing clip or straiten it if possible. The panel is removed by simply pulling outwards away from the door. If the clips come out with the tab, you should remove the clip off the tab and reinsert into the door before placing the panel back onto the door. If it's missing, you can visit your local dealer. Clip part # C2C35342 About a $1 each
The panel itself is made of metal, with a thin wood veneer attached to it. You pull strait out on it. Give it a sturdy tug. You can use a nylon pry tool underneath it if needed. If you feel uncomfortable with it, take it by your local dealer.
01-22-2007 12:38 AM
