Loud hissing noise when I remove Oil Filler Cap
You shouldn't run the vehicle without the oil cap installed. Unmetered air will cause you all kinds of issues. The crankcase is a sealed system, and is why the inlet is in the breather hose after the MAF. Both the o-ring on the filler cap and it's tower as well as the dipstick should provide positive sealing.
EsRay (11-24-2017)
