Low Coolant Level Light
I had an issue similar to what you describe, except the coolant level was actually a bit low. If the car is worm - the level appears OK, but that's just because the fluid expands.
Turns out my coolant expansion tank was leaking from the breather hose connector - very small leak, but enought to trip the sensor at one point.
The leaks that I had was very small and the fluid evaporated before it reaches the floor.
Drive for a bit, then check the hoses and the plastic expasion tank for any "wet" spots.
There is a small hose that enters the top of the tank - the nipple usually cracks - try moving is up and down a bit - mine came right off.
Note: only do the last bit if you have a replacement tank rady or you are close to the dealer, cause if that nipple is completely broken you can't drive anymore.
Wolfy
05-28-2024 08:06 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
