lower ball joint on wheel knuckle
This lower front ball joint on the suspension upright is a pressed-in fitting and is exceptionally difficult to replace without the correct tooling. Many shops will not replace these due to the difficulty. In fact the design was later changed to move the ball joint onto the wishbone, and it then becomes a lot simpler and easier.
No doubt somebody will now say its easy !
Unfortunately, yes, you have to replace the whole knuckle, (UK=Hub carrier), which comes complete with new ball joint. I was at a seminar in 2011 on the X350 and the head of an independent mentioned the great difficulty in replacing this very joint. Of course it was later redesigned to put the ball joint onto the wishbone, which makes replacement a lot easier.
hawaiianjag (08-31-2014)
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 05:46 PM
1964Daimler
09-09-2015 11:28 AM
