Lower Radiator Hose Access?
There are several hoses connected on both radiators on the bumper side. What needs to be removed to access? For example: The "Hose for the Auxilliary Radiator" attaches to the side. The pictured plastic cross member right above the bumper cover gets in the way. I couldn't find removal instructions for it; it seems it may be connected to the head light units, but it isn't logical that it would be.
What has to be removed to access the lower hoses? I assume the bumper cover &, I think, the referenced plastic cross member too.
Thanks and best,
Steve S.
Thanks and best,
Steve S.
Hi Steve,
in all the years I have worked on my cars, I have come to the maxime "when in doubt, remove more, instead of less, to facilitate access".
For me, this has worked out fine and saved a lot of bruised knuckles.
Having said this, at the time I removed the bumper cover, the headlights (I wanted to replace the bulbs anyway...), and the plastic support to which the headlights are attached.
With this, removing the radiator hose was quite easy by using the clamp removal tool with the remote cable.
Furthermore, I used the occasion to remove and clean the washer reservoir (it was dearly needed).
Best regards,
Thomas
Best regards,
Thomas
Thanks, Thomas! Very helpful. I agree completely that removal is a good option. The "easier" hose could not be removed with any of my implements of destruction because of the plastic piece.
Sounds like I should remove the bumper cover, then each light module.
Will the long plastic piece removal be fairly intuitive? I looked in the body manual and couln't find the section that details how the removal is done.
By water reservoir do you mean the one that holds the window washing fluid?. I will definetly find one of the stickies on the ground points and give them a good cleaning.
Thanks again & have a great day!
=> yes, that's the right sequence.
=> yes, it will be. It is only screwed on and you should not have any trouble identifying the screws.
=> yes, I do.
=> yes, I do.
Best regards,
Thomas
Was Ist Das
Is this part of the radar? Need to disconnect in order to remove the plastic bar/platform atop the bumper. With my track record with connectors, thought I should ask how to disconnect? When I press on what seems to be the spot for releasing, nothing seems to happen. Also, it seems that it should be able to be removed from where it is held to the body? Any thoughts?
There is even a third radiator, a little guy, down there! What will I find next?
Hi Steve,
if I remember correctly, that's the temperature sensor for the external temperature for the climate control. The release is pretty straightforward, maybe you just the help of a small screwdriver. The release is on the bottom part of the plug as shown in your picture.
The radar for the cruise control is down below, as it is behind the bumper cover you will see it when you remove that.
As for the radiators... the car has 4 or 5. ;-)
Best regards,
Thomas
Best regards,
Thomas
04Xjrsteve (06-25-2024)
The mechanical bits of Motorcars are EASY to work on. Electricals getting into bun-fights.... not so much.
The "frightening" part is when one hits evidence of poor design or a bean-counter 'win' over better engineering .. or even simple (lack-of) common sense.
Ex: Zinc plating of "speed nuts" and other trim and panel fasteners protects the Aluminium. Until ... the sacrificial Zinc becomes locally depleted. Thereafter, the Aluminium chassis will sacrifice itself to 'protect' the exposed Iron & Steel of the fastener.
Exactly, Bill & Thomas! I would use the word "frustration" to describe a goodly part of it. Things that should be easy to find aren't.
The Answer IMHO: AI
While I'm more knowledgeable about tech than my peers, my knowledge is still very limited. As we speak, AI could be putting together a shop manual for just our VIN number. It could have an index and a glossary. It could create a chart with every torque, etc. It could make readable diagrams and feature demonstrative photos. & list each part number in every reference to it.
I guestimate that this sort of thing could eliminate 50% of the "work" out of these projects. I see AI in the same way a framing carpenter sees the nail gun.
Have a great day!
Steve S.
The Answer IMHO: AI
Have a great day!
Steve S.
The Answer IMHO: AI
Have a great day!
Steve S.
The Answer IMHO: AI
Have a great day!
Steve S.
They didn't call them "Artificial" Idiots 'back in the day,' as labour of biological manufacture was still cheap and willing enough there was no shortage of factory OEM, 'genuine' parts.
Called the most Artificial of THEIR Idiots "Politicians", rather.
If any more "AI" gets into a Jaguar's DNA than has already driven the electronomics coven confusingly psychotic?
I shall have to periodically administer an overdose of "stupid pills" just to be able to keep the b***h focused on serving as a motorcar..... rather than a viciously vacuous wannabee quiz show host.
04Xjrsteve (07-03-2024)
Any time you think con-putas are getting half way 'smart"?
Task the pretentious con-puta and a human child with the same goal in a crowded venue and see who succeeds or fails:
"Go and find your own biological Mother"
"AI" would lose to most ANY mammal on that score.. and even a few reptilians?
giandanielxk8
01-07-2019 10:31 AM
