Lower temperature thermostat for XJ
CIarification, the OEM thermostat is working perfectly. While driving I see you it open and close by monitoring coolant temperature. Just it runs hotter than I like. Drops to 93C then climbs to 95C. Cycles between.
I wiould like a thermostat that is set to 180 - 183 degrees instead of the OEM 190 degree. Several suppliers show a lower temperature model. But they a one piece units. The correct thermostats are four parts and twist to lock into thermostat housing.
Can only find 190 thermostat so far.
The reason these cars have 195 thermostats is the engines are designed to run hot. Any thing below 230 will not harm them. Running cold is not good for modern engines. Ever tore down a 60s engine that had 160 to 180 thermostats, they are filthy from not cooking the moisture out. I just tore down a 60s nailhead Buick. Absolutly filthy even the oil pump screen was imprinted in the pan crud. If your car is not overheating leave it alone.
The following 2 users liked this post by Terrific:
motorcarman (08-20-2022),
pkoko (08-22-2022)
Thanks!
It was easy to leave the 190 degree in there. Not having a lower temp to install.
I replaced expansion tank last week and figured it was a good time to swap if I ever was. Gates and Stant both show a 183 degree model a 2006 XJR.
But both most likely fit a x308. Flat, one piece unit. Not an insert model. BTW the Stant was stamped Motorad.
Never have seen over 95C. Even after freeway exit and stop and go traffic. But did not start monitoring coolant temperature until recently.
