lug nut covers
give these a try
https://www.bing.com/videos/search?q...1&&FORM=VDRVRV
I would try #3 method first. If you have to cut off the stainless cap, be careful as the number one problem with chiseling, is damage to the wheel.
Try using a socket that is so tight that you have to knock it on with a hammer.
The socket does not need to go all the way on just enough to get a good grip.
After you remove the nut cut off the stainless cover which will be damaged and just use the steel nut
until you can replace the whole lot.
Removal of these capped nuts needs a hexagonal socket, not the usual 12-sided one. It's a 19mm and there are lots of these wheel nut sockets around. I bought mine at the local motor factor.
This is mine and it worked a treat after I tried the usual 12 sided, which rounded the corners.
https://www.halfords.com/workshop-tools/tools/sockets-accessories/laser-alloy-car-wheel-nut-socket-air-impact-19mm?cm_mmc=Google+PLA-_-Tools-_-Sockets+&+Accessories-_-697128&istCompanyId=b8708c57-7a02-4cf6-b2c0-dc36b54a327e&istItemId=liiwll&istBid=tzpq&_$ja=tsi d:94971|cid:865695754|agid:42483196263|tid:aud-297219197929la-402305078589|crid:203186066565|nw:g|rnd:1509468359 5987067432|dvc:c|adp:1o5|mt:|loc:9046460&gclid=Cj0 KCQjw-JvaBRDGARIsAFjqkkqR4pa49FcBL9awcGabPk_kcHcIkBkp1ok uj9Z7WXygZN9-meLa0mYaArWVEALw_wcB
Norri (07-12-2018)
https://www.ebay.com/itm/20-Pc-OEM-C...item25fbff6de7
Just remember to pick up the correct sized lug wrench too from a boneyard and throw it in your trunk.
Byte Me
07-09-2019 10:56 AM
texevora
05-06-2019 10:07 AM
Vipercf
23
06-14-2015 09:55 AM
