MAF wiring
They don't really mean anything. They are just the wire colours so they can be physically traced. Just trace them back to the ECM on the wiring diagram to see what they do. -ve in triangle is a common signal ground by the ECM. "I" in triangle is signal output from sensor to ECM. I believe any number in a circle is always to a switched +ve line.
MCFastybloke (10-08-2022)
