master window switch
I don't post too much because most of my questions are forums. But this has me stumped. Here is my issue. I have a xj8 2004, When I use the master switch for the right rear window it will go down then when I use the switch to bring the window back up the windows goes down. I can use the rear door switch and it works fine. I did replace the switch and still has the same issue. I did do a search of the forums and did not see any answers for this problem. any help would be great.
master window switch,
Hi there, I had a similar problem with my 2007 xj8 last year, only it was the front passenger window behaving the same way, I also replaced the switch pack but had the same problem, anyhow by accident I found the cure, open the driver door and gently pull the wiring harness then press the length of the harness, sounds like witchcraft but I have not had the problem return,I can only think there is a break in the wire and this getle movement makes a connection,, just wait and see I have probably gave it the kiss of death,, hope not,, good luck,,,,
regards
Dave
2007 xj8
regards
Dave
2007 xj8
projectjag
11-22-2015 12:35 PM
projectjag
11-22-2015 11:12 AM
