Mechanic THINKS!!! The timing chain is causing throttle body limp mode issue?
Hi everyone this is my first post after buying my x350 in 2015 with 140,000 miles.
I recently had my throttle body changed at a independent jag shop because it started to fail. I've attached the codes I had prior to any work being done as well.
After dropping my car of at the shop the mechanic calls me and says " you need a new timing chain and tensioners because your car is making a noise when you start it up for a second then goes away. I explained to him that the car always made the noise since I brought it 2 years ago. He says I definitely need a throttle body also to solve the limp mode issue. The mechanic replaced the throttle body front height sensor and rear sway bar links. I payed drove the car about 5 miles stopped at a red light stepped on the gas once the light was green now the car goes into limp mode after throttle body replacement. I have the car towed back to the same shop now the mechanic is saying the timing belt is causing the limp mode. My question is could the timing chain cause the throttle body to fault. The noise I hear during start up sound more like a VVT Unit issue based of my own research recently.
Ralph Hemp (07-12-2017)
Received 2,266 Likes
If I remember correctly, that if just the tps is changed, a recalibration is required. I'm probably all mixed up. I just remember a procedure from an old post that required that the throttle position be recalibrated. Can anyone chime in and confirm or correct me? I believe it required something like - throttle all the way down in the multi-step procedure. Seems like Ralph's mech is missing something. Everything shown points to a throttle issue. Hence the work recently completed.
Lean code is an easy one, and should not shut the car down, unless it's a gaping hole. But we have seen a HUGE hole in the intake elbow in a recent post, and the car still ran. Leak only in bank 1. Need to see fuel trims, and other data to pinpoint causes. The mech should have these as he couldn't/shouldn't recommend parts solely on dts codes. Give us more data so we can help.
When did we get timing belts? Somethings fishy.
Ralph Hemp (07-13-2017)
What messages are you getting when it goes into limp mode? Did you try starting it 5 times in a row to get it out of limp mode?
I had mine go into limp mode once and I was convinced it was due to rain and moisture. Put dialectric grease on the outside of the plug to the throttle body and it's been thousands of miles since and never saw it again. I got this advice from the s type r forum if I recall which has the throttle body positioned similiar to the XJR.
That definitely sounds like the old Throttle Position Sensor malfunction. In the old days when these cars were still fairly new, we had to get entirely new throttle bodies and they were not cheap. A new sensor should do the trick.
Ralph Hemp (07-14-2017)
UPDATE: Aftet another week the independent jag shop finally comes to the conclusion that they installed a bad TPS and throttle body. Now they are going to replace it again. Mean while I've located a new Jag shop with a better reputation. It's a lot further away but, I'm going to take the trip if all goes well for an inspection of the work...
Still no success
Received 2,194 Likes
Find another mechanic hes full of it. I would check the electrical connector on the throttle body cause theyre plasic and fail all the time. Mine on mine is down to no connector left and tight pins holding it on(i know on my list of stuff to do) any electrical drop out on these circuits will go into limp home. The chain tensioners and guides on the 4.2 are pretty damn robust. While you defintly have wear(im at 150k too) that is not your issue with restricted performnce. That is where i would start but more test needs to be done, and chacks made. Imo he is guessing and not experienced with jaguars.
Ralph Hemp (07-21-2017)
Ralph Hemp (07-29-2017)
