Message Alerts
Message Alerts
Having trouble with various messages popping upon the dash: ie: DSC Failure, Air suspension Fault & one other I can't recall. This happens randomly but usually when I'm in heavy traffic & out of town. The Air Suspension Fault doesn't make me lose power, but the others do. I had the battery disconnected & it worked for 3 weeks, then yesterday the Air Suspension Fault popped up again. I do not know what that means. Anyone have any issue with these messages. I have a very well taken care of XJ8 2004.
This. Random unrelated faults are usually a battery issue. We've owned two Jaguars now and both have had oddball faults that ended up being the battery. The 2000 S-Type we had wouldn't allow the radio to turn on while the car was running and would work with the engine off. Jaguars are so voltage sensitive that this is common even when the battery is plenty strong enough to start the engine.
wladja (01-25-2016)
Replaced my OEM Jaguar battery today. Was installed Sept 2013. It bit the bulit in under 2.5 yrs. I dont know how the car was stored durring the winter, before I purchased it. If stored poorly or a lot of short trips in the cold, that could have beat it up bad. I'm going to contact the service manager at the dealer where it was installed, and see if at least I can get it pro-rated. It should have had at least a 3yr warranty. Most batteries have at least a 30 month no prorate. Ive never had a battery only last 2.5 yrs.
It did solve all my problems.
The christmas lights really get your attention !
wladja (01-27-2016)
Thanks for your information. I never thought a battery would have such short life but if it stops this un-nerving situation, I am happy to get a new battery, worth every penny if the flashing lights & pop up messages cease. It's is really scary when you are in the fast lane of 4 and you get these & your power shuts down.
Thanks,
Wladja
XJ8 2004
Taken care of like a member of the family.
Thanks,
Wladja
XJ8 2004
When I bought my first X350, I changed preventively the original battery which was 6 years old but still good, because I knew how sensitive theses cars are to a good battery.
To get some extra reserve, I purchased an AGM Start and Stop Plus battery from Varta (this is the original supplier of batteries for Jags in the EU). I think that AGMs are now put originally on X351s because of the Start and Stop systems to increase mpgs and reduce CO2 emissions in the EU. The battery was very strong until I sold the car this year.
That's why I am now thinking to put an AGM on my current SV8 Portfolio 2006 that seems to show a battery weakness (I had already a Christmas tree and the weakness will probably show up again).
https://www.jaguarforums.com/forum/x...hboard-155654/
AGM batteries are worth the extra expenditure, much more resilient and accept deeper discharges that are so detrimental to baatery life
Plus 3 on the battery as a possible cause, our cars are so so sensitive to weak / failing batteries and cause all sorts or weird / random issues.
I've had batteries last in cars easily for 4 or 5 years, but it seems that todays more modern cars are much heavier on them. This combined with severe cold weather, lots of stop / start short trips and yes, 2 years is good.
I've probably went through around 3 -4 batteries on my 9 year old Audi A6 and its a whopper at 110AH and 850 CCA, recently upgraded to 110AH and 920 CCA.
I'd say look at replacing your battery and see how you go...
