Midwest winter gas mileage
Old 11-25-2013 | 10:10 PM
Vinnyboy's Avatar
Default Midwest winter gas mileage
Hi Folks,
I've noticed that my gas mileage has gone from a summer city street avg of 12.5L/100km (24mpg) to 14.5L/100km (19mpg) in temps of 25-30F. Does that seem normal to you? I use Shell 93 0ctane, 29500 'km' on a 2009 VDP.
Also it seems no one had any comments on what the typical stationary idling should be. I mentioned my prev Taurus X was almost dead quiet and a mild idle on the Jag similar to a Honda Accord. Is that normal? Only asking because I was wondering if a luxury car as the VDP would almost be silent at a stop and if there was a mechanical issue.
The air filter is new too.
Thanks for your help
Old 11-26-2013 | 04:47 PM
reyesl's Avatar
My MPG has dropped a bit also, noticed yesterday that I was getting 25mpg vs 30+ in the summer. My car is kept in a heated/cooled garage so warm-up time is not a factor.
Old 11-26-2013 | 08:07 PM
trosty's Avatar
The car takes longer to warm up to operating temperature which means it runs leaner for longer? Just a guess, I may google it now to find out why it happens....
And here's a good explanation of why using the old Austin Mini metro... http://www.metrompg.com/posts/winter-mpg.htm
Old 11-26-2013 | 08:09 PM
Mikey's Avatar
Winter blend gas carries less energy than summer blend. That alone would contribute to increased consumption, plus the longer warm up times.
Old 11-26-2013 | 09:58 PM
Having the same trouble here in the UK on both my A6 and my sons X type.
Always happens at this time of year, usually see around at least 5-6mpg shaved off what we can achieve in the summer time
Old 11-27-2013 | 07:26 AM
Partick the Cat's Avatar
Old 11-27-2013 | 10:46 AM
Vinnyboy's Avatar
Thank you for all your responses folks.
Still curious on my idling question though, any thoughts?
Old 11-27-2013 | 11:21 AM
Mikey's Avatar
Not sure what you're asking/saying. (?)
Old 11-28-2013 | 09:19 AM
Vinnyboy's Avatar
Hi Mikey,
Well the best way I can describe it is like this, when you're sitting at a red light waiting, have you ever noticed how the engine is idling? Is it so smooth and quiet that you wonder if the engine is even running or does it feel like a typical midsize car or old Volvo 4 cyl idling with that slight vibration coming thru the steering column?
As I mentioned before, my Ford 2008 Taurus X was so quiet idling at a stoplight, that I wondered if the engine had stopped, it was such a smooth engine for a car it's size.
I only ask to see if their is some adjustment that needs to be done.
Thanks again
p.s. What is the reason you mentioned the regional forum?
Old 11-28-2013 | 10:43 AM
Mikey's Avatar
My S-type has the quiet idle you describe, guess you'd need to compare with others with exactly the same car as yours though.
The Canadian regional section reference is part of my standard sig. Have a look now and then to see what's going on or post what's new in your area.
Vinnyboy (11-29-2013)
Old 11-29-2013 | 02:52 PM
trosty's Avatar
my 150k miles, sits quiet at idle on 500 rpm. No vibration or rumble or anything in both summer heat and winter cold.
Vinnyboy (11-30-2013)
bdboyle
09-16-2019 06:58 PM
bwc
12-03-2016 05:05 PM
FabCat
09-22-2015 02:26 PM
worrasf
09-22-2015 01:34 PM
10 XF Premium
09-14-2015 07:55 PM
Quick Reply: Midwest winter gas mileage
