Mina Gallery Exhaust Delete Kit
Old 04-25-2017, 10:27 AM
BlacXJRcat's Avatar
Default Mina Gallery Exhaust Delete Kit
I'm considering the exhaust delete kit from Mina but I'm afraid it will be too loud. I deleted both resonators and installed an x-pipe in their place. One option would be to install one of the two resonators after the x-pipe or a Magnaflow muffler with inner tru-x pipe, which what essentially would be a dual x-pipe system similar to Corsas' system for Mustangs.
Do you think this would be a good combination? Has anyone done straight pipes without resonators? Any issues with backpressure?
Thanks for the comments.
Old 04-26-2017, 12:17 AM
Datsports's Avatar
trust me a twin system with x pipe and no mufflers or resonators
is not something you or your neighbors want to listen to .
it sounds terrible !!
i have twin 2.5'' with 200cell cats , x pipe. two silver bullet resonators in the middle .
then down the back two glass pack step through resonators .
its a bit loud still . but acceptable. it sounds heavenly .
Old 04-26-2017, 08:15 AM
BlacXJRcat's Avatar
Thanks for the reply. That's what I thought and that is the reason I was thinking that putting back one of the resonators would help. Could you tell me which brand you used for the resonators and glass packs.
Any bad drone with your setup? Video?
Old 04-26-2017, 03:06 PM
34by151's Avatar
I have 100cel cats, xpipe, and dynomax VT's for the rear boxes
Its too loud so much so I can no longer hear the supecharger wine.
Also the VT's become an open pipe when you step on the gas which is louder still.
I need some center resonators
34by151
Old 04-27-2017, 12:59 AM
Datsports's Avatar
it had no drone until i fitted the 200 cell cats . now it has a little one but is isn't bad at all .
and only at 2500rpm under load . really quiet inside the car coasting.
the x pipe and cats are magna flow , the two center resonators are silver bullet's .
and the rear step through glass packs are turbo flow. all 2.5''.
i have voice memos of it but this forum i don't think will except them .
and nether does youtube .
i have a memo of 2.5'' system with stock cats .
and one with the cats / x pipe and no resonators .
which will be enough for any one never to do that again .
and one of the current system .
if you want them then PMme your email and ill send you them .
unless some one has an easy trick to upload to the thread ?
Old 04-27-2017, 09:59 AM
BlacXJRcat's Avatar
I may do four round resonators (two each side) which would be more expensive or a dual in/out high flow muffler in the middle and two bullets in the back.
Decisions decisions!
Old 03-04-2021, 12:39 PM
tberg's Avatar
Received 2,579 Likes on 1,419 Posts
Reverend Sam,
The Mina exhaust system is much quiter than the stock exhaust. I know because I have the Mina exhaust and one day, three of us forum members got together, revved our engines and listened. My Mina system was not nearly as loud. I soon afterwards added an X-pipe and removed the center resonators. The tone of the exhaust changed to a deeper, richer sound, but is still very quiet. I still have my old OEM exhaust and may someday put it back.
Bcrary3
01-15-2018 01:28 AM
Rathskeller
02-25-2016 04:47 PM
X-TypeMentality
07-03-2015 01:05 AM
Evoking
04-15-2013 04:22 PM
bfsgross
34
06-29-2010 02:07 PM
Quick Reply: Mina Gallery Exhaust Delete Kit
