Mina's intake tube/pulley mod. Worth it?
I'm kicking around buying the intake tube & pulley combo. Is it really worth it or just money down the drain?
Jaguar XJR Performance pkg1: Intake and Pulley 2004-2008 - Mina Gallery Inc
Thoughts?
Thoughts?
this is what you absolutely need to do. Get the Cadolfy(look him up here) intake pipe. Great quality and stainless steel. With that remove the flap inside the airbox...If that doesn't work for you get the mina air intake. Modify it to receive cold air(you can check my post on that)...THEN....Perhaps get that pulley. The pulley is a PIA to do...The other intake mods relatively easy. If blower whine is your thing youll love it. If not....PASS on the intake mods!
VinnyT (02-18-2016)
I'll take a look at Caldoofy's intake tube and maybe a pulley later. Thanks for your input XX!
V
I have removed that flap a while back. I have seen posts on the Caldoofy pipe, but saw the Mina 'kit' online too. I'm pretty good at wrenching on engines but was hesitant about the pulley swap. Wasn't sure how tough that was.
V
V
So for starters get the intake pipe and cold air kit....Youll love that sound....I mean..I do. Also I kept the flap solenoid connected and zip tied it hidden. Not sure I needed to but didn't know if a code would trip if disconnected
