Mongoose JLR SDD software installation?
It's important to download a flawless version of IDS-SDD also following a scrupulous procedure.
IDS-SDD with its numerous associated calibration files is a sensitive application and if only one file is corrupted or badly downloaded, it will not work correctly.
I purchased a Mongoose (non Pro) and, separately, v130.03 on 2 CDs that I downloaded on a dedicated laptop, fresh XP-SP2 install and only the required apps (Adobe, Java, etc.) in their required previous versions, no web access and setting the clock on a fixed date of August 2012.
It has worked flawlessly since then, no issue to read VIN and to run.
Other procedures and softwares may work, but apparently not everytime...
I tried V130 in winxp mode on a win7 64bit machine and it installed ok and the mongoose jlr was recognised (i used the pro version) but when it came to auto reading the VIN , it always came back as unknown VIN. Then when I tried to input it manually it came back unknown and would progress no further. I even changed to the non pro mongoose driver versions and still the same!
That's when I went and tried V125 and it worked flawlessly.
Just 0.02p worth.
Just 0.02p worth.
I uninstalled V142, downloaded V130 files, and installed V130 and its updates 1 and 2 over the last three days. There were no errors encountered during installation.
When I run the SDD program it opens IE and goes to:
http://localhost:8080/user//user/request_login.action
When I enter the user ID and password from the Offline Authentication pdf file, it either says Authentication failed because TOPix service temporarily unavailable or it just sits there with its little blue wheel turning over the word identify for hours at a time.
I tried turning off the Windows firewall but it made no difference.
Any suggestions? Anyone? This is still my Toshiba with Win7 Home Premium 64 bit OS and the SDD icon set to XP compatibility mode.
Did you completely remove every facet of the previous versions from your previous install. Did you clear the registry?
Did you go through every sub folder and delete every IDS, SDD, Mongoose JLR driver and their associated components prior to the new install? If you didn't, there is a good chance anything new is not going to work.
You need to turn off the firewall and any anti virus software.
Other than that, maybe a complete restore of your operating system and a clean install of the SDD V130. I've only done that procedure about 15 times now and it never gets any easier or quicker.
I freakin, hate SDD.
I agree that I've never had software that took so long to install and to uninstall; it must be freakin complicated or freakin inefficient.
I created a restore point just after v142 install. Should I go back to that and start over? I didn't think the authentication process would be the actual v130 program, but perhaps it is part of it. OK maybe I need to start over with the old Sony and v130 and see where that goes.
philwarner (09-28-2015)
I reset the date to Aug 1, 2012 and tried SDD and it seems to be stuck on the little blue circle as before. There was also a tray icon that popped up for Flexnet software manager and when i clicked it it said the authentication certificate was out of date and did I trust it anyway. I said yes twice when the same window popped up again and then no. i don't know if this is part of the SDD or not. In any case IE is still sitting there with the little blue wheel over the word identify. Guess it is time to start over on the Sony Vaio installation or i might turn off my home network and see if I get something different if the net is not available.
#28
I expect that when you install the SDD software it installs various backend operating system files that start when the computer starts.
These probably check internet and update status even if the SDD isn't running in the background and run as a service.
This is why it is essential you never let it have access to the internet at any time, I would turn off all internet access by disabling the wifi adaptor in the control panel.
#30
I got the same little stop app or open browser window and IE opening, and an "internet not detected" screen and continued to the user and password entry, entered the user and password from the readme file and got a user authentication failed screen; the computer date was 8/2/2012.
I did not download or run the Panasonic setup files mentioned in the readme when I downloaded the v130 files assuming they were for Panasonic Tuffbook users only. ("1. Download and extract the Panasonic Configuration Script on to the target desk top (NewPanasonicLaptop_SDDConfig_V13.zip)" Are these needed on a non-Panasonic machine?
#31
#32
#33
I am new to the SDD software, so I have never used or installed it but it seems I have a similar problem as philwarner had.
I can go to the login screen,
I get a message: Identification has been verified
and then: User Authentication Failed.
Complete story:
I bought a refurbished Dell laptop with Windows 7 pro 64 bit, I5 processor, SSD as harddrive and a original Mongoose Pro. The people where I bought the Computer and Mongoose from installed the Mongoose software (maybe here lies the problem?).
I installed Norton Anti virus without a problem. Then I downloaded all the files from Index of /265935/idscentral
JLR PanasonicScript-Setup
SDD_145.00_FULL
SDD_145.01.001
SDD_145.01.002
SPA_145
VDF_JA_145
VDF_JV_145
VDF_LA_145
VDF_LV_145
And did the installation according to the manual. Because I was having problems having the Panasonic Script to run (Windows error, needed to install: C++2005 Service Pack 1 MFC Security update.exe ) I used the Windows software remover and deleted the Mongoose (maybe not complete?) . After I installed C++ there were no problems installing the SDD. But when I try to login it will give me the message: User Authentication Failed .
I tried to set Norton on non active with no succes.
Any thoughts? Idea's?
At this point I think it would be easier to install a cracked version instead of original.
Or do I need to run the DrewTech Mongoose software?
Complete story:
SDD_145.00_FULL
SDD_145.01.001
SDD_145.01.002
SPA_145
VDF_JA_145
VDF_JV_145
VDF_LA_145
VDF_LV_145
#34
IMHO you have gone through too many tweakings in your softwares' installations.
From my experience (said above already), it is very important to start from clean. After many unsuccessful attempts, for me it worked only after a fresh re-install of the OS on the laptop (Win XP Pro-SP2) and loading of the many IDS-SDD and calibration files from two CDs.
I used a clone Mongoose (non Pro) and v131.03
Since then works like a charm.
#35
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
The SDD version you are using requires you to log in to topix. The last version that did not require a log in to topix for use of all the SDD functions was V130 (or V134 I cant remember now!).
So if you don't pay your monthly dues to topix and have a legit username and password, its all for nothing. It will read you dtc's (all of them) but I am quite sure you won't have access to many (read if any) functions to change stuff because it is all centralised on Topix now and downloaded as required via the internet.
Also using Win 7 64bit isnt going to help, ideally you need a 32bit Win Xp SP2 laptop. With Win 7, You have to use VMware which also has its own irritating settings.
It cannot for any reason, under any circumstances, be allowed to connect to the internet once the SDD has been installed. All the pre requisite software and settings should be done prior to installing the SDD.
I could go on and on about what not to do, because I spent more than an abnormal amount of time trying to get a version (and I have many versions) of mine to work.
It really is a lot of trial and error and luck, there are many threads on this board that should be read too prior to installation to give you an idea about what the process and pit falls are.
I can give you a link to access V125 or 130 if you like, just pm me.
#36
I finally took off the hair shirt and put down the willow switches and bought an icarsoft i930 to read/erase my air suspension and other codes, although I did pick up a set of Dell version XP Pro install CDs at a thrift shop the other day and might try again from scratch if the wounds ever heal and my memory dims enough to override the extreme frustration of my Mongoose/SDD experience. For the time being, though, the Cobra has won.
#37
I spent a lot of time trying to get the Mongoose to work and then it gave up the ghost.
Bought another from B Diagnostics (basically the same one) and that failed too
but they refunded my money.
I sent the old one one back but they did not bother collecting it and it came back to me!
Now I have another from China and am putting off the installation!
At least they are cheap to buy!
If only I could get them to work!
#38
#39
#40
Multiple posts won't get you loved.
https://www.jaguarforums.com/forum/g...5-v130-194139/
Bob's answer is definitive.
GGG (12-22-2017)
