Mongoose screen shots and lack of options.
SDD
I am currently running a Win 7 64 bit Virtual PC that , has been running win xp SP3 32bit in a virtual mode.
I have installed SDD vers 125 (the last version used for X350) and it seems to work perfectly. Now that's great.
My intention now is to see if I can copy, zip and transfer the .VHD (which is the whole virtual OS HDD to another pc running virtual pc and install it and see it works. If it does I will upload the file , allowing everyone else to download it for their easy installation and use. There is still a lot to look into like, final file size (zipped) etc.
Watch this space.
Watch this space.
SDD
Hello,
I am running a later version of the SDD software on Windows 7 64-bit and it is fast and easy to use in legacy mode together with my Mongoose Pro Cable from China to check for fault codes.
However, I will not use it to program the ECM as this could end up as costly mistake.
As a backup, I have SDD130 ready to go in a VM on the same PC with the older Mongoose cable.
Best regards Robert
Best regards Robert
Leslie Graham (Levitikon) (06-09-2019)
Hello,
Programmed the FEM with SDD157 and Mongoose PRO and got a CONFIG F error for my efforts. Used SDD130 and old Mongoose on VM with XP which cleared it. THe User Interface behaved the same in both cases. Maybe of help for someone.in the same situation as I was in...
Best regards Robert
Best regards Robert
I was going to do a comprehensive write up with pictures for the Mongoose JLR (clone) and my X350, but have identified a couple of issues that I have with my Win 7 32bit OS and the SDD version 1.42.06
They are as follows: (mongoose is connected and disconnected in some pictures, but all tasks were tried with the mongoose connected and the vehicle running to provide stable power).
Screen 1.
After connecting the mongoose and starting SDD I can automatically collect my VIN (only with the veh running though and it is still unauthenticated), run through the dealer screens, The no internet screen, the internal modules selection screen, limited functions screen (no internet to TOPIX) and then go to settings screen to select my unit variables (MPH,PSI etc) and then in this instance I select the service functions to collect all my current vehicle data and am left with this screen.
Attachment 118197
It took a while but I now have all the module abbreviations down and can identify what they are so all well and good (so far).
Screen 2 & 3.
I check some system settings for the PC and get this. I see nothing wrong with this screen and my unit settings screen:
Attachment 118198
Attachment 118199
Screen 4.
After going through a few separate screen selections using the tabs along the top of each session module, a lot of my screens say words similar to this.
Attachment 118200
Screen 5 & 6.
So finally I get to see some DTCs.
Attachment 118201
Attachment 118202
I notice that there are rather a lot of them :-( . One I see is for a suspension issue I just repaired so i decided I would run a DTC reset and managed to figure it out by selecting the next tab and there are two options to "RUN"
Attachment 118203
I run the DTC reset and that works.
Wow, this SDD is cool stuff, let me see what other things I can calibrate, change or adjust via the software.
Well after many frustrating hours of clicking, selecting, tabs, restarting the laptop, the car and all manner of things. It would appear the only things I can do with this is:
Attachment 118204
Read the service checklist (which actually doesn't work because at every step I get this message).
Attachment 118205
I have clicked on the diagnostics and drilled down through the selections to provide and answer on how to fix the relevant DTC issue but when I get to the end of the selections and select continue (which I presumes would give me an answer) it just returned to the original list of DTCs at the beginning. Where's the extras tab?
Miffed is a polite way of saying how I feel about all this.
So to say this whole venture is and has been a waste of time and money on my behalf is quite the understatement.
So for the $42 for the clone Mongoose JLR and the cheap laptop (32bit CPU) and hours of installing 3 or 4 ( I can't remember exactly now how many versions of SDD), Installing an OS for a 32bit laptop without updates.
I get to read my DTCs that my previous old OBD2 reader could read anyway.
What am I doing wrong to not get any of the calibration screens or run screens that I see others getting, like this:
Attachment 118206
Screen 1.
Attachment 118197
Screen 2 & 3.
Attachment 118198
Attachment 118199
Screen 4.
Attachment 118200
Screen 5 & 6.
Attachment 118201
Attachment 118202
Attachment 118203
Attachment 118204
Attachment 118205
Attachment 118206
(I know it's an old post....... really old post)
Finbarr1975
09-16-2023 03:52 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
