Motor running rough & grinding noise - dealer stumped!
#161
Bosch 9607 iridium electrode platinum ground Advance Auto Parts dot com Buy Bosch Iridium Spark Plug 9607 at Advance Auto Parts + coupon code ccabin + mail in rebate http://www.boschautoparts.com/Promot...bpad_11_OL.pdf
steveinfrance (05-11-2012)
#163
I wish Jaguar had not told me to wait to 100k on the plugs, as you say, I think 60k is about right.
I do have to correct you on one point though, both the IFR5N plugs I pulled and the Bosch I replaced them with have platinum grounds. When I spoke with NGK tech support they said the platinum gives them the 100k service interval, with just steel and iridium he said half that life.
The Bosch plugs were only $7 each less 40% coupon less mail in rebate made them a really good deal.
We like two-way streets, yes??
PS.....that's a helluva deal on those plugs!
xjrguy (07-06-2012)
#165
#166
Since so many have been following this thread, I thought I would continue to post updates and progress.
Due to XJRGUY's knowledge and keen interest in this issue, I decided to drive to his dealership last week. First off, I must note Steve's knowledge and genuine love of these cars reminds me very much of virtuoso, like Van Cliburn.
Anyhow, Steve took the better part of a day to analyze two things, the RPM idle drop and decreased MPG. Taking into consideration everything the other Jag dealer had done he came to 2 somewhat simple conclusions: there is an air leak on bank 1 including around the newly installed throttle body causing the engine management to compensate by adding more fuel and an obscure error in the VAPS computer located in the instrument cluster providing inaccurate data and therefore incorrect RPM compensation.
Rather than replace the instrument cluster he re-flashed the software hoping this would solve the problem (note: in my line of work most hardware failures can be attributed to software corruption despite the fact some people are quick to assume it is the equipment that needs replacing).
After a week, so far no RPM irregularities and for the most part the car is "purring" like a kitten. I can't say it is 100% perfect as I believe the vacuum leak is contributing somewhat. So off to the original dealer who installed the throttle body!
In the meantime I must note it was well worth the trip and I am very pleased with the results. It is quite a relief to finally work with someone who knows what he is doing!
Stay tuned....
Stay tuned....
xjrguy (07-06-2012)
#167
Received 6,337 Likes
#168
Stay tuned....
Stay tuned....
First, thank you not only for the glowing review, but also for taking the time to come here and fill everyone in. There have absolutely been many folks watching and contributing on this thread.
I am very relieved that the course of action we took may have made some improvement. Like I said, your possible visit was both anticipated and feared. So glad we didn’t come up completely empty. I guess time will tell. Now if you can just get to the bottom of the air leak we found……..
Bear in mind I don’t think the throttle body itself really enters into the equation here. It appeared to me the air was entering down low, below the area of the throttle body; possibly at the seal/gasket between the induction elbow and the supercharger. We also know there was leakage noted at the front, which would probably mean at the joint between the RH intercooler and the cylinder head. See the areas marked on the attachment. Unfortunately, we can’t completely discount any of the joints you see in the diagram at this point.
I’m going to sit and sweat a little longer until you come back after a further period of time and tell us the idle has been consistent. Then I’ll be happy.
Thanks again, and good luck with the hunt! I’ll be ‘round if you need anything. I'll stay tuned.......
Cheers,
#169
Hi all, have relocated to Auckland NZ for my business
Jahummer,
Anyone checked the magnetic clutch on the compressor? There is a bearing in back of those, and since the compressor can take 9 or so HP to run, loading up that bearing when it is faulty can be a bit noisy. I haven't been able to follow the thread, had my hands full the last few weeks, so sorry if it's already been suggested.
Cheers,
#170
Jahummer,
Cheers,
Jahummer,
Cheers,
Cheers,
#171
The compressors on these cars are clutchless, yes really ! The pump action is varied using a swash plate.
http://delphi.com/pdf/contact/brochu...ompressors.pdf
Apparently, use of these compressors means cars with smaller engines can run air con much more easily, as the compressor doesn't suddenly "thump" in and upset the engine control.
The following 2 users liked this post by Fraser Mitchell:
Jag XJ8 Red (07-11-2012),
ooootis (07-12-2012)
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
innzane
09-02-2015 10:08 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
