Motor Shaking
My motor is shaking in idle and has low performance. I changed the plugs today as they were due but it didn't make any difference. The engine malfunction light is on and a message is displayed "reduced engine performance". Any suggestions or will I need a diagnostics performed ?
Yes, is the answer. The car fault detection system has detected a potentially damaging fault, so has put the engine into "restricted performance" mode. It posts a code into memory to give mechanics a clue as to what could be defective. Basically the system compares values from various inputs from engine sensors and compares to what they should be in the particular circumstances.
I now know it's a bad coil. I switched coil #5 with #1 and now the display is saying #1 is misfiring. Yes I used pre-gapped iridium plugs. Now I have to do some coil shopping ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Thanks everyone
Thanks everyone
How many miles has your car ?
The car has 80,000 miles on it now. The new coil is now installed and she is purring like she used to. I shopped around for a new coil and Jaguar had everyone beat on the price, it looks a little different then the old ones so I'm assuming it's an improvement just like the blower resistor pack.
davidboger
10-01-2015 10:13 AM
