Motorcars Ltd. is selling a complete air spring conversion.
I have no connections with Motorcars Ltd., but thought this might be of interest to some.
Air Suspension Conversion Kit - Motorcars LTD
2600 - seriously - replacing 4 air springs plus compressor - 2100 - then I can ride on air. Everything from the Range rover and Land Rover forums indicate the ride quality goes down significantly - which is why they put it in in the first place - it sells cars (Jag knows the 2nd and 3th owner will most likely not go with original parts). If the set was 800-1000 as it is for the Rovers I would do it. the steel spring set comes with electronic that satisfy the computer and obviate errors. In a year or two you can most likely get it cheaper. Does anyone knows what the lifetime for the arnott air springs means? - assume it does not really mean lifetime?
I agree
Yeah , but "Lifetime " sounds so gooood !
The annoying thing is that how long both Land Rover and Jaguar had over the years to get this damned system reliable and chose not too, so sad.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
2004, 2005, air, complete, conversion, conversions, convert, jag, jaguar, kit, kits, oes, spring, suspension, xj8
