Multiple Cylinder Misfire Codes
I recently had my 2008 XJ8 tuned up by a mobile mechanic (new spark plugs, coils, manifold gaskets, egr valve gasket, throttle body, map sensor). The car does not immediately start when I turn the key and when it does start, there is a bit of a shake. The check engine light was on but is now off. I received the following codes today when I took the car to Auto Zone:
P0301
P0302
P0303
P0304
P0305
P0306
P0307
P0308
P0300
P0316
P0506
P0175
P0113
Any suggestions on what the issue may be is appreciated.
Thanks,
Peter
P0301
P0302
P0303
P0304
P0305
P0306
P0307
P0308
P0300
P0316
P0506
P0175
P0113
Thanks,
Peter
JX350 (06-01-2020)
P0301
P0302
P0303
P0304
P0305
P0306
P0307
P0308
P0300
P0316
P0506
P0175
P0113
Thanks,
Peter
P0301
P0302
P0303
P0304
P0305
P0306
P0307
P0308
P0300
P0316
P0506
P0175
P0113
Thanks,
Peter
Received 2,679 Likes
@petalidi, there are two issues with having all those misfire codes:
- There is an interruption in the fuel supply, or a massive amount of unmetered air is entering the inlet manifold
- If the misfires continue, one or both catalysts will be damaged and need to be replaced
George05 (05-24-2020)
