My $200 Jag has a oil leak
If memory serves, you can remove the filter and housing without draining the pan.
Two other areas that are prone to fluid leaks on these cars are the power steering fill tube at the 90 degree bend and the transmission cooler lines at the hose crimps, worth checking out as you go through the car.
