My 04 xj8 brake system is not working, Please help!!!
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
I just replace my font and rear brake pad on my jaguar 2004 xj8. Re-installed all the pads and parts, pump air out of the brake line just incase there is any. I start the key and step on my brake paddle, and there is no pressure at all. Tried to pump the brake paddle for a while using my feet, still not thing happen, check brake fluid, it is full to max. Is any out there know what happen to my brake system? please help. Thank you in advance.
Newbie to the site.
Newbie to the site.
pump air out of the brake line just in case there is any.
Why did you feel a need to bleed the hydraulic system ? You have done something wrong or appear to have done whilst bleeding the system.
Others may post with more detailed knowledge but from your symptoms you seem to have introduced air rather than removed it. Of course you don't say whether you had an existing brake fault. Were the pads worn-out or did you replace them for another reason ?
https://www.jaguarforums.com/forum/x...service-61323/
Please use this link to my post regarding XJ brakes. There may be some things you may have missed regarding the, rear calipers, parking brake system and resetting. Open the attachments for needed information.
BrentGardner
28
04-26-2024 03:08 AM
Robert1968
06-24-2017 11:16 AM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
