My analog clock stopped working??!!
(fixed) My analog clock and light stopped working??!!
Just today my analog clock stopped moving. Any idea what the problem is? When I press the + or - buttons it seems like it wants to move, but doesn't.
If there a fuse for this? Also the light on the clock still works.... please help.
Top Answer
07-31-2014, 11:07 PM
OK... I fixed both problems. The clock is now working and the bulb to it lights up again!
I appreciate any help I get from this forum so I always trying to give back good advice too so you can troubleshoot your Jaguar issues! So....
First I checked all the fuses and they were all good.
Next I knew I had to take apart the dash to get to the clock. I carefully snapped out the main piece of wood and unscrewed the piece holding the a/c vents with the clock. I didn't have to pull the vents completely out, just enough to disconnect the clock tabs and push it out.
Then I took apart the clock. The problem with it was the hands felt stuck. I literally had to wind up the clock with my finger, going counterclockwise... once with the hour hand and once with the minute hand. This loosened it up enough to work again and keep the time!
Now it was time to fix the bulb... the original one was fried.
I had to peel off the green film from the old bulb to use on the new one.
2721MF is the type of bulb you need to fix your clock light! I picked it up at the local auto store. It fits perfectly. Put it all back together and it should be working.
The hardest part of the job was putting the wood panel back on. It was difficult for me to snap on the right side of the panel that is next to the air bag piece. I hit it hard with my palm and it finally snapped on! Try not to break anything, lol. Start with the bottom of the panel and then the top and sides... until everything it sitting flush again. You will need to pull the leather trim surrounding the navigation to slide the wood in place FIRST!
Hope this thread helps yall out! I will be happy to answer any questions you may have!
I found this site that has the fuse locations and descriptions. It's for a 2005 XJ but the 2007 should be about the same. I did not find one that addresses the analog clock specifically. There were some that were instrument clusters or packs though. You may want to inspect those to see if the fuses are OK.
jaghelp.com: 2005 XJ Fuse location and id
Attachment 92007
Attachment 92008
Attachment 92009
Attachment 92010
Attachment 92011
Attachment 92007
Attachment 92008
Attachment 92009
Attachment 92010
Attachment 92011
The following 13 users liked this post by Hustle Hyde:
2catlimit (07-02-2016),
chillyphilly (06-30-2016),
clivedavies (06-26-2016),
Don B (07-01-2015),
dukeflyer (03-11-2020),
and 8 others liked this post.
Confused
Attachment 92007
Attachment 92008
Attachment 92009
Attachment 92010
Attachment 92011
Attachment 92007
Attachment 92008
Attachment 92009
Attachment 92010
Attachment 92011
Thanks!
You don't need to fully remove the center console. Just nudge it back about an inch or so to give the wood trim some extra clearance. Also, no need need to remove the instrument cluster surround. Just lift the upper right hand tab a bit and slide the air vent unit out after unbolting. No need to even touch the air bag wood cover either.
well to move the center console back an inch you still have to essentially "remove" it as you've completely unmounted it from the vehicle (1" or 1' = same amount of work). also I found theres a lot of forcing required of the center vent side tabs due to the raised cross shaped plastic blocks on them designed to keep them locked in under the gauge shroud and airbag facia, so as it's a handful of screws, I found it easier to just free the gauge cover and airbag panel. I spent some time trying without removing those, and judged it was taking longer than removing 5 screws...
but it all ended up great thanks to the forum - thanks!
all these solutions are for the three gauge systems clock. My problem concerns the analogue clock displayed on the nav screen which isn't a real clock it's in the nav screen software but looks and operates like an analogue clock.
The problem is the hands have disappeared !! so no time is shown, although all the marker digits (ie the numbers) are still showing.
So has my software suffered a stroke? and some part of the software has given up?
confused. Cottonwood.
