My car is hot (way too hot)
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
It was a sad evening. Planned to go to the movies with the my better half. Started the car and smoke started comming from the engine bay - more under the driver side wheel.
It was running ok, no warning lights. I turned the engine off and poped the hood open, nothing looked out of the ordinery.
Anyone want to take wild guess, what on eart could be burning?
Before you start it, check the coolant expansion tank and see if the coolant is at all oily/gray. Also look at the oil to see if there is any hint of antifreeze in it. If the answer to either question is yes--that's not great news (head gasket/cracked block).
If not, take a look at the exhaust manifolds and cat converters to see if there is anything stuck to them. It could be the aforementioned plastic bag or similar--obviously good news.
Best of luck.
Best of luck.
Received 2,192 Likes
I got some time to look at it today. Coolant looked pink-orange as usual. Oil was a bit dark, but it's due for change anyway. I looked around the engine bay and there were no signs of smoke, no weird smell.
I started the car - works as new. Go figure.
I'll get it checked at the dealership - just to make sure.
Thanks everyone for the support.
Vector
US Lower Atlantic
08-26-2015 05:36 AM
