My strut change nightmare
Anyone else used W83021 tie tod puller on the ball joint?
My local Auto Value store did have a front end service kit, part# W89303, available for free rental (deposit returned upon return of undamaged tool) that included the Wilmar separator, so I picked that up.
Back under the car, I was able to get all the nuts loose without issue (amazing). I made sure to mark both sides of the nut and bolt on the inner part of the control arm, as this is a concentric bolt for camber-caster adjustment. While using the special tool to get the lower ball joint out, I ran into a problem in that the jaw wouldn’t open far enough to get leverage on the top of the bolt. Great. IF the OTC tool did open larger, I’m sure it would’ve worked. Thinking for a moment I was going to have to hammer on the part to get it free, I looked at the rest of the tools in the kit, and found that the Tie Rod Puller (available individually as well, part# W83021) might work. With a couple turns of the ratchet and a loud pop, it worked perfectly and the ball joint was free without damage.
3/4" Forged Ball Joint Separator
Guy-Pierre Boucher
09-16-2015 06:55 PM
Gerard Radimaker
09-13-2015 11:33 AM
34by151
09-06-2015 06:14 PM
02jagstype
09-04-2015 09:20 PM
